![]() | Home > Maintenance & Modifications > Swivel Kit for 2011 Puma |
Rosco Member Since: 03 Dec 2010 Location: Burntwood Posts: 1875 ![]() ![]() ![]() |
After much head scratching, can anyone confirm I'm looking at the right kit?
My chassis number is FA, so I need kit DA3180P? Cheers 2007 - Stornoway Grey 90 XS SW - Gone 2002 - Black Discovery II - Gone 2014 - Montalcino Red 110 XS SW |
Porny Site Sponsor Member Since: 31 Aug 2009 Location: Sutton Coldfield - West Midlands Posts: 812 ![]() ![]() |
DA3180P is the kit for ABS equipped late Defenders (inc Puma) - however, its not an OEM kit so wont have Timken Bearings and Corteco Seals. Its Britpart own brand kit, IRB
The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 |
Ian, thanks for the quick reply.
Any suggestion on which kit to get instead then? I do have ABS. Keen to avoid Britpart as much as possible given their lack of glowing reviews 2007 - Stornoway Grey 90 XS SW - Gone 2002 - Black Discovery II - Gone 2014 - Montalcino Red 110 XS SW |
I spend a lot of money with Britpart... but you have to just know what your buying. Some of their own brand stuff isn't actually bad.
Ian IRB The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1130 ![]() ![]() ![]() |
An addition if it's just the seals. On our MY15, Land Rover fitted seals which don't have an outer dirt seal/lip >-( (the arrows point to the gap where there should be none and to the dirt that gets in there).
It seems there are different part numbers for the seal but they are not related to whether it's the proper one or the 'Excel-optimised' i.e. cheap one. When I ordered LR059968/OEM I got a Corteco seal (12€). I also ordered another LR059968 and got allmakes (3€) - it has the old part number FTC3401 imprinted, but both have the outer seal and look very much the same. ![]() Click image to enlarge |
LandymanStefan Member Since: 30 Aug 2017 Location: Surrey Posts: 886 ![]() ![]() ![]() |
Hello chaps, looking to do this on my early td5 soon. I was wondering if any of you have changed the swivel seals using this method. Looks far easier than striping the hub. My swivel ball is in good order just the seal has become old and begun to weep. I can’t see any problem doing it this way.
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3630 ![]() ![]() ![]() |
Nothing wrong with that approach if your swivel bearings, CVs and hub bearings do not need servicing.
Just be prepared that the swivel/hub assembly is very heavy. When assembling back, ensure that the swivel does not rotate excessively in the other direction of the steering stop, as could damage the new seal. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
Kevlar Member Since: 28 Oct 2020 Location: Prague Posts: 84 ![]() ![]() ![]() |
I just fitted this kit to my 2010 DA3180G it was Britpart but with Timken bearings and Corteco seal.
https://www.island-4x4.co.uk/swivel-90110-...33080.html Quality looks good, I fitted everything myself, first side took me a while but second side I got done in about 5 hours. Most of the time spent cleaning up the mess from the old leaking seals. The guy at Island 4x4 is very helpful with selecting the correct parts for your Defender. Kev |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6015 ![]() ![]() |
That’s always how I do mine. Even if fully rebuilding them. Remove as one big part, get it on a bench to work on. But if all else ok just new seal, refit, add one shot grease. A 14mm ratchet spanner makes it a quicker/nicer job. |
