![]() | Home > Puma (Tdci) > Blown Hole in air inlet manifold |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5981 ![]() ![]() |
How is the engine running??
A melted plastic inlet manifold can often be caused by a stuck, bent valve. The EGR gasses should pass through a cooler. |
piechipsandpeas Member Since: 12 May 2021 Location: Albany, Western Australia Posts: 230 ![]() ![]() ![]() |
I had a crack develop in mine in pretty much the same spot last year, thankfully didn't blow a hole in it. Noticed some oily black marks on underside of the bonnet.
A genuine replacement from Ford is much cheaper than the same Ford part from Land Rover. |
natyeo Member Since: 27 Jan 2013 Location: Bentham Posts: 138 ![]() ![]() ![]() |
Hi landy andy running fine before , Hi piechipsandpeas will look for ford version before I order , cheers 2014 2.2 90 hard top , Warm M8000 , Scorpain winch bumper, Ashcroft rear atb
2012 2.2 tdci 110 Utility 1993 110 CSW Warn M8000 , Scorpain winch bumper , 2" lift , Roamerdive overdrive, on going 1971 Hybird 200tdi, 2 x truetracs,Extrem winch bumper, M8000, GKN overdrive & Coils 2" lift, Glynn Lewis cranked rear trail arms 1971 Series 3 88, Perkins 4203,M8000,SATs,O/D, |
Replaced inlet manifold with a good second hand one off ebay with new seals, sorted egr out , , after a local had two goes at a re map and stuck in over fuel on dpf, and then bloody fuel pipe breaks and poor parts supply sorted with a mix of old & new, ended up sending ecu to Bell Auto's , back in 3 days with stage 1 150 bhp , great service and running well. 2014 2.2 90 hard top , Warm M8000 , Scorpain winch bumper, Ashcroft rear atb
