Home > Puma (Tdci) > Blown Hole in air inlet manifold
natyeo
United Kingdom 2014 Defender 90 Puma 2.2 HT Santorini Black
Any one ever had this happen , fault code P0101 , replaced MAF sender , 3 days later whilest green laning , yellow engine light on, limp mode then smoke from under bonnet, jumped out opened bonnet to find more heavy smoke to find burning smell and hole melted in inlet manifold as big as my thumb near EGR in let pipe , fault code P0101 & P2263 , Thinking EGR stuck open with heavy heat build up.
 2014 2.2 90 hard top , Warm M8000 , Scorpain winch bumper, Ashcroft rear atb
2012 2.2 tdci 110 Utility
1993 110 CSW Warn M8000 , Scorpain winch bumper , 2" lift , Roamerdive overdrive, on going
1971 Hybird 200tdi, 2 x truetracs,Extrem winch bumper, M8000, GKN overdrive & Coils 2" lift, Glynn Lewis cranked rear trail arms
1971 Series 3 88, Perkins 4203,M8000,SATs,O/D,
Post #970988 13th Nov 2022 5:39pm
landy andy
How is the engine running??
A melted plastic inlet manifold can often be caused by a stuck, bent valve.
The EGR gasses should pass through a cooler.
Post #971036 13th Nov 2022 10:29pm
piechipsandpeas
Australia 2013 Defender 110 Puma 2.2 SW Indus Silver
I had a crack develop in mine in pretty much the same spot last year, thankfully didn't blow a hole in it. Noticed some oily black marks on underside of the bonnet.
A genuine replacement from Ford is much cheaper than the same Ford part from Land Rover.
Post #971052 14th Nov 2022 6:03am
natyeo
Hi landy andy running fine before , Hi piechipsandpeas will look for ford version before I order , cheers 2014 2.2 90 hard top , Warm M8000 , Scorpain winch bumper, Ashcroft rear atb
Post #971138 14th Nov 2022 7:08pm
natyeo
Replaced inlet manifold with a good second hand one off ebay with new seals, sorted egr out , , after a local had two goes at a re map and stuck in over fuel on dpf, and then bloody fuel pipe breaks and poor parts supply sorted with a mix of old & new, ended up sending ecu to Bell Auto's , back in 3 days with stage 1 150 bhp , great service and running well. 2014 2.2 90 hard top , Warm M8000 , Scorpain winch bumper, Ashcroft rear atb
Post #982121 11th Feb 2023 11:06pm
