Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement
Page 54 of 112 <123 ... 535455 ... 110111112>
forzahog
United States 2016 Defender 110 Other Works V8 Auto Fuji White
stevemfr wrote:
There are 2 exceptions for the moment that have to do with our hardware configuration and we are working on a solution to be released ASAP: the activation of ACC (active cruise control) and Active Park Assist.
Will this be an update to the firmware of the IID tool or a new hardware version of the IID tool itself?
Cheers,
Kyle 20MY Defender 110 Fuji White
Post #1009017 26th Sep 2023 6:21pm
Hairy Dan
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Chawton White
malibu wrote:
Hi Ian, did you compare the CCF file before and after David fixed the error message?
Sorry for the late reply I don't seem to be getting updates to this thread for some reason. I did compare the ccf file before and after and there doesn't appear to be any changes, ie the things that needed changing were changed but I didn't have the error after it was done via Pathfinder, which is confusing. I did try and look over David's shoulder when he was doing the updates but he has his laptop and Pathfinder system set to the Chinese language Laughing Cheers Ian
22MY Defender 110 D200 SE, Fuji White.
Kielder 4x4 Safari
Instagram @defender_v8
Post #1009025 26th Sep 2023 7:02pm
Hairy Dan
Bob Heijnen wrote:
Hairy Dan wrote:
Yes I was one of them soon as I switched the LSPC on I got the emergency brake error, luckily David at Hunters Prestige was able to activate it for me with Pathfinder.
Any idea about the extra changes by David? It must be only a software setting and not a recallibration of some sensor if I understand it correctly.
Bob see the answer in the above post Thumbs Up
But yes it is only a software change. Cheers Ian
Kielder 4x4 Safari
Post #1009026 26th Sep 2023 7:04pm
lightning
ls there any way to alter the settings of the cruise control? lf you set the speedometer to the more accurate setting it works great, increasing the actual speed of the vehicle to within 1mph of my GPS speedometer at 70mph.
But it doesn't alter the cruise control. So if you set cruise at 70mph the vehicle is doing 67mph according to the (more accurate) speedometer.
lt would be nice to have the cruise control show the same as the speedometer. There must be a setting somewhere for it.
l've left the speedometer on the less accurate setting as l don't like the cruise control showing a different reading.
Which is a shame, because on this setting at an indicated 70mph the vehicle is actually doing 66mph.
Post #1009044 26th Sep 2023 8:21pm
chpsk8
United States
@stevemfr
First, thank you for all the efforts you and your team put into this tool. It has proven its value to many of us.
I'm a relatively new user and have a couple questions about the errors that a lot of us see with braking errors and 2WD only when we make some of these changes.
I find it interesting/frustrating that some users don't get these errors, while others do. Comparisons of CCF files don't show anything obviously different, so some are stuck without being able to make some of these changes.
ATPC for one: One change to CCF available and it works for some, but not others. But if they use Pathfinder they can clear the error, or make it stick...
Do you have any tips for those of us that can't make that change stick without errors? Is there something else we should try changing to make those changes? Does it have to do with the stock configuration of some of the builds? for instance, my vehicle was spec'd with 18" rims. Does that change the brake config so I get this error?
I'm more than excited to hear more development is happening on ACC and Parking. I'm equally concerned I'll get a braking error or 2WD error. Crossing fingers when those are released (assuming firmware update) that we'll all get it.
Thank you for all the work you and your team does to give us tools like this.
Post #1009068 26th Sep 2023 11:06pm
malibu
Australia
I am guessing, but I feel this project is very large. ie trying to reverse engineer all settings for a range of vehicles that each have there unique features using the same software. I also then modules need to be recalibrated/updated after some settings are changed. Therefore I would imagine GAP would be working on them either as one at a time or grouping like issues to resolve. Then needing to test the solution on a range of vehicles. This is a very time consuming task.
It appears they are making ACC and Auto Parking as the priority, which I would imagine would make the most users happy. After that I am hoping they will look at the Auto TR and ATPC and TA2 for the Discovery.
I think they are also working on making changes update quicker. ie some people have made changes, but they haven't shown on the screen for several days.
I am really impressed with the work so far. It is amazing that they are giving us the ability to change so many settings, and yet nothing is being broken. The worst we get is a 2wd or brake error, that fixes itself when we reverse the settings.
So I think we all need to be patient and thank GAP for making such an amazing product.
If you have time at GAP, it would be great if you could maybe outline your developement plans, so we have an idea of what features maybe comming next. Thank you so much.
Post #1009073 27th Sep 2023 4:23am
mmbanf
Italy
hi, from what I have learned in this time, no one (I think) has managed to enable the auto TR or ATPC function, only users who already had a standard configuration with "auto configurable TR" have ATPC enabled.
so there is probably something in the factory configuration that we are missing.
second thing, every error that occurs is always somehow related to the detected speed of the wheel, (change in tire size, Auto TR, Atpc, Acc, Brake diameter) in fact, as can be seen from this photo by ccf editor, also the tpms calibration is involved in the setup.
I tried to change the tpms calibration value, unfortunately without success, but it is strange that in the file of our multican-581 cars, tpms cal is repeated three times... two text and one hexadecimal.
Post #1009074 27th Sep 2023 6:39am
mmbanf
Italy
hi, I see two ccfs relating to speed detection, have you tried changing both?
MultiCAN-838 Speedo Market
Market 0 (+3.5% +2km/h)
MultiCAN-577 SpdoCalPercentScale
3.5% Scaling
Marco
Post #1009075 27th Sep 2023 6:48am
malibu
Australia
Hi @mmbanf,
Great info. Maybe we can ask people on this forum if they can confirm your assumption.
I was woundering if anybody that has been able to activate ATPC can confirm if they have Auto TR pre installed.
Post #1009076 27th Sep 2023 7:02am
mmbanf
Italy
hello, I asked a user who successfully enabled "Atpc control", he confirmed that he already had a "configurable tr" as original equipment.
Marco
Post #1009077 27th Sep 2023 7:19am
malibu
Australia
I am sure you are correct, but I think there are several people on hear that have been successful, it might be good to have a 2nd person confirm, as it could also be something else.
Post #1009079 27th Sep 2023 7:22am
lightning
As l see it there's obviously something else that needs to be changed, like when you alter the speedometer accuracy and it doesn't change the cruise control.
On this setting you just end up with the cruise control reading incorrectly but on the terrain response system it's clearly generating an error of calibration.
On the old TD5 Defender you can add cruise control and it works perfectly. But if you then add overdrive, the cruise won't work with it engaged because the system is seeing the incorrect data from the speed sensors.
Post #1009084 27th Sep 2023 8:06am
malibu
Australia
I think when we change CCF codes, sometimes the GAP tool runs a supporting functions that triggers a calibration or update of module/s. I tihnk these are being built by GAP, but I imagine each takes time and they need to prioritise. Maybe cars with Auto TR don't need the supporting function for ATPC as it is already set. I am confident that over time, the GAP tool will allow us to configure the items we require.
We need to keep in mind the ability to modify Pivi Pro cars was only released a few months ago. It is amazing it does so much already.
Post #1009085 27th Sep 2023 8:20am
stevemfr
France
Hi guys,
The problem is, that we as a small company do not have access to all models and all configurations of every Land Rover available worldwide. We actually rely on our users to provide feedback - people like Hairy Dan or Marco or many others who do a terrific job of trying things and compiling information. Bow down
When we started this a little over 10 years ago, more often than not CCF changes required only changing a single setting in one ECU. Now all systems are interlaced. And the problem is that LR is not giving this info out and if we were to do the R&D to make all of this work out of the box, the IIDTool would cost easily 3+ times what it now costs.
We do our best to make the IIDTool as easy and foolproof to use as possible with 'Restore' functions, etc. But there is a limit to what we can reasonably offer.
And thanks for the kudos from everyone! Thumbs Up
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s,
2 FL1s and a L663 on the way
Post #1009238 28th Sep 2023 11:25am
chpsk8
United States
Thanks @stevemfr for the information. Since we are in essence crowd sourcing the errors, is there anything that we could do to organize the data that would help your team?
I understand the layering of processes that JLR has in it's programing, we see that more and more of that in my industry as well. It's not as easy as turning over one rock to find the answer anymore.
If there's anything we can add to our findings as we receive errors I'm sure the user groups would be on board to tag on some additional data if that helps your process.
Post #1009264 28th Sep 2023 2:14pm
