![]() | Home > Maintenance & Modifications > ACF50 vs Lanoguard |
They are not comparable. ACF50 is good at what it does but is a relatively short term treatment that will wash off and need to be reapplied. A typical approach is to apply ACF50 and then something like Dinitrol over the top. There's lots of detail about this in the long running Corrosion Prevention Guide thread.
Lanoguard has been described as cheap and easy to apply but also as a glue. I'm not convinced that it's the rust-proofing panacea that many seem to think it is, to be honest. One of its selling points seem to be that you just spray it on and that it's a 'five minute job'. Having seen the lengths gone to for a professional treatment in cleaning and prepping before applying the final product, I just can't see how that's going to work ![]() 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
jim4244 Member Since: 13 Apr 2014 Location: Bedfordshire Posts: 986 ![]() ![]() ![]() |
Thanks Darren
Whenever I have used Lanoguard I have had the chassis and underside steam cleaned and hot hot washed down at the local truck wash. Then rusted areas have been painted in Aqua Steel and then, when everything is dry, the Lanoguard was applied. I must admit that the ease of applying Lanoguard without all the mess of Waxoyl is a great case for using it. Hmmmm I order the ACF50 thinking that it would offer similar protection to Lanoguard… Jim |
MartinK Member Since: 02 Mar 2011 Location: Clackmannanshire Posts: 2677 ![]() ![]() ![]() |
Agree with Darren. I'm also a motorcyclist and use various ACF's and Dinitrol products.
This is a fab test of the various ACF's. I do use ACF 50 frequently (great for the rivets on a 110, and various parts of the engine bay). XCP is great but very "gloopy" and leaves a dark brown film. ACF365 is good after a wash to get into the nooks and crannies but requires regular (i.e. after every wash) application. ACF's are great for bright work (like say banjo bolts on your brake lines and rivets, door hinges, bonnet catches, parts in the engine bay etc) I use Dinitrol products on the chassis etc. Not tried Lanolin Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2679 ![]() ![]() ![]() |
I like Lanoguard (not just the smell….
![]() ![]() It’s easy, mess free, if you get any one the driveway it just disappears after a short while without having to do anything or even cover the ground. And because it is easy I find that I am more likely to apply it when I have a spare hour. Also because it is DIY it just makes you feel good after doing it. Have fun….and be quick, winter is coming. ![]() |
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3411 ![]() ![]() |
you won't need 5 litres of lanoguard for a single vehicle, the 2Litre pack is more than enough for a defender with some left over. ![]() |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2286 ![]() ![]() ![]() |
I agree with other members.
ACF50 is great as a periodic/occasional corrosion prevention and protection treatment rather than a permanent underseal or chassis protection. If you are a fettler or tinkerer like me then you’ll find the use of ACF50 quite an addiction ![]() As for underseal and chassis/cavity protection I’ve always used, and have never had any issues with, Dinitrol. I use a 3 stage approach like many others, and as already said that subject is covered extensively already on here ![]() |
Mossberg Member Since: 29 Feb 2020 Location: Lancs Posts: 553 ![]() ![]() ![]() |
I have just used fluid film on the underside of the truck. Lanolin based but it wS a lot cheaper than Lanoguard. Just ordered 19ltrs for £127 delivered.
It applied similar to Lanoguard - I used the same spray - but looks wetter when applied. I then spread it with a paint brush (I put plenty on!). There is plenty on YouTube about fluid film. I bought mine from a company called Comfish Marine, so being sold to people with boats! I used the "Liquid A" but there is also NAS which looks a bit more like grease. I presume I have picked the correct one for spraying under the truck! ![]() Click image to enlarge ![]() Click image to enlarge Fluid film next to 2ltrs Lanoguard. I didn't think 2 litres was enough for my 90, but I may use more than I need too! |
Just to add to my previous post, the reason I have used Lanoguard/now fluid-film is that I want to observe my chassis. My truck is 1993 vintage and if it starts to corrode I want to know. Having to do this yearly will make me look too.
Also, I would not apply anything that is not clear over any type of paint, especially the devil's own formula black paint that is applied to many replacement chassis parts. |
Leamreject Member Since: 19 Dec 2020 Location: Middle Earth - Leamington Spa Posts: 970 ![]() ![]() ![]() |
I use ACF50 on our blood bikes before winter, short term it works well but after a winter of everyday riding its horrible to remove in many places. All of the road dirt has stuck to it. But it protects the surfaces very well so I continue to use it
![]() If I’m not on a bike it’s because only a 4x4 will do… 2011 2.4 Puma 90 HT |
LandymanStefan Member Since: 30 Aug 2017 Location: Surrey Posts: 886 ![]() ![]() ![]() |
I originally painted my chassis with a dinitrol/waxoyl type product called ardrox av30 and I own a motorcycle that I spray yearly before winter with acf50. From my experience I much prefer acf 50 as it’s easy to remove at the end of winter using a water based degreaser and wash off and it seems effective at preventing corrosion. The issue with the more permanent dinitrol/waxoyl solution is if you want to sand something back and do a bit of painting or touch up on the chassis if you see a bit of corrosion peeping through its an absolute nightmare to remove, it clogs up flap discs wire brush wheels etc. Also if you want to re apply the product it’s a so difficult to remove to apply a fresh layer it’s frustrating. I wish that I just sprayed it with acf50 when I first got it then I could top up, wash and re apply whenever I wanted.
Thanks for your thoughts guys.
Here’s the plan - Anything that moves slightly underneath has been sprayed with ACF 50 so bushes, ball joints, prop shafts etc. When dry I will over spray the entire chassis and underside with Lanoguard. Mossberg - I paid £105 for 5L of Lanoguard so you found an absolute bargain! Any chance you can post some photos of when it has dried/cured on the chassis? Jim |
Will do Jim. I will see if I can add some of when I applied it.
This is it going on after warming it in some hot water. Before it was warmed it did not atomise as well. ![]() Click image to enlarge This is it on. When it goes on it just looks wet and it can run. I used a paint brush to even it out and get rid of the runs. It seemed to run more than Lanoguard- is that good or bad? Runny means it will get into places easier but I am not sure how it will go regarding staying on. I did feel it would get into nooks and cranies. It did seem to drip quite a bit, but that could well be because I applied so much as I was happy I had plenty to do so! ![]() Click image to enlarge I will take some more photos after its been on two or three weeks and post them up. |
Jhollow Member Since: 27 Apr 2022 Location: Ontario Posts: 89 ![]() ![]() |
Fluid Film is readily available over here (the grease looking one) and it is what I and many others have used primarily for rust protection. I have also watched this guy as he does numerous tests on various undercoating rust protection products and his finding were typically pro Fluid Film, until the latest video. He found something better.
This is a new product out by the same people that give you PB Blaster. Blaster Super Shield is also a lanolin based product. I will be giving it a try as I just picked up 6 aerosol cans as I am in the States at the moment. I don't know its availability in Canada or across the pond. 2006 90 originally registered in Italy |
SteveG Member Since: 29 Nov 2011 Location: Norfolk Posts: 675 ![]() ![]() |
If it’s Dinitrol - previous applications can easily be removed with white spirit. |
