Home > Maintenance & Modifications > Sticker removal
Willem
South Africa 2004 Defender 110 Td5 SW Galway Green
Sticker removal
Good day all,
Does anybody have a good method for removing a weathered Defender sticker from my grill frame?
Many thx.
Post #965802 23rd Sep 2022 6:10pm
The Zee
United Kingdom 2014 Defender 110 Puma 2.2 USW Indus Silver
This should work :
Wash grill area so there are no abrasive / grit particles
Use a hairdryer/hot air gun to carefully warm the area softening the adhesive
Use either dental floss or fine fishing monofilament in a up-down sawing action working from one side to the other.
The badge should come away after cutting it away.
Use a solvent like white spirit or tar remover to remove the sticky residue
Importanty go slowly and carefully use more heat if needed or get some of the solvent under the badge to help , and dont try to peel/lever the badge off before completing the cutting - the edge if the badge will damage the paint Zaid-M
www.DefencePhotos.com
2014 Defender 110 Utility, 2.2 Puma, Indus Silver
Not just transport more like a religion
Post #965823 23rd Sep 2022 8:02pm
Screbble
Careful use of a hairdryer will aid removal significantly.
Post #965824 23rd Sep 2022 8:03pm
Willem
Thx guys for the advice. Will give it a go. Thumbs Up
Willem
Post #965827 23rd Sep 2022 8:32pm
Rubbing alcohol (carefully) maybe of use a
A toffee wheel maybe of use too. The latter isn’t much use in corners and gaps though.
These are a couple of things that maybe useful in addition to the posters above ideas.
I’ve used the dental floss before, works great. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #965830 23rd Sep 2022 8:40pm
Leamreject
Italy 2011 Defender 90 Puma 2.4 HT Fuji White
This should work very well. Thumbs Up Ride like you stole it!!
If I’m not on a bike it’s because only a 4x4 will do…
2011 2.4 Puma 90 HT
Post #965831 23rd Sep 2022 8:44pm
You haven't said if you have an a/c grill or a non-a/c grill, but it is worth bearing in mind that the a/c grill support panel is plastic and the non-a/c panel is aluminium. There are likely to be things you can do to an aluminium panel that you couldn't safely do to the plastic version.
Post #965837 23rd Sep 2022 9:17pm
Willem
I have the a/c plastic grill. Any things I have to look out for?
Post #965839 23rd Sep 2022 9:27pm
I'd be a bit more careful with heat or a toffee wheel with the plastic panel, but I don't have one so don't know how fragile/robust they are.
Post #965841 23rd Sep 2022 9:33pm
Leamreject
Hair dryer heat will be fine on any panel, it will be less hot than siting your car in the sun on a hot day.
I used one frequently to remove body wraps quite successfully, it may leave some glue residue but an alcohol wipe or sticky stuff remover will finish that off.
And when I say hair dryer I don’t mean a heat gun which can get you into trouble Whistle Ride like you stole it!!
2011 2.4 Puma 90 HT
Post #965850 24th Sep 2022 7:33am
^^^ Good point and an important distinction, a hairdryer certainly won't do any harm.
My brain was saying "heat gun" when everyone had written "hairdryer".
Post #965851 24th Sep 2022 8:33am
Screbble
I don’t own a hair dryer for reasons that would be obvious if you saw me, but someone I know does…
I have used it to remove decals from numerous vehicles without any problem.
Any adhesive residue can be removed with a panel wipe or white spirit.
I used this method to remove the Defender decal from my plastic air con grill surround with no issues. Thumbs Up
I wouldn’t use a heat gun on my hair…but then again I haven’t got any…
Post #965853 24th Sep 2022 9:12am
