![]() | Home > Maintenance & Modifications > Sticker removal |
| The Zee Member Since: 26 May 2019 Location: Salisbury Posts: 303
This should work :
Wash grill area so there are no abrasive / grit particles Use a hairdryer/hot air gun to carefully warm the area softening the adhesive Use either dental floss or fine fishing monofilament in a up-down sawing action working from one side to the other. The badge should come away after cutting it away. Use a solvent like white spirit or tar remover to remove the sticky residue Importanty go slowly and carefully use more heat if needed or get some of the solvent under the badge to help , and dont try to peel/lever the badge off before completing the cutting - the edge if the badge will damage the paint Zaid-M www.DefencePhotos.com 2014 Defender 110 Utility, 2.2 Puma, Indus Silver Not just transport more like a religion |
| Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2347
Careful use of a hairdryer will aid removal significantly.
| Willem Member Since: 13 Apr 2022 Location: Durbanville Posts: 11
Thx guys for the advice. Will give it a go.
Cheers Willem |
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21022
Rubbing alcohol (carefully) maybe of use a
A toffee wheel maybe of use too. The latter isn’t much use in corners and gaps though. These are a couple of things that maybe useful in addition to the posters above ideas. I’ve used the dental floss before, works great. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
| Leamreject Member Since: 19 Dec 2020 Location: Middle Earth - Leamington Spa Posts: 970
This should work very well. If I’m not on a bike it’s because only a 4x4 will do… 2011 2.4 Puma 90 HT |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18036
You haven't said if you have an a/c grill or a non-a/c grill, but it is worth bearing in mind that the a/c grill support panel is plastic and the non-a/c panel is aluminium. There are likely to be things you can do to an aluminium panel that you couldn't safely do to the plastic version.
I have the a/c plastic grill. Any things I have to look out for?
I'd be a bit more careful with heat or a toffee wheel with the plastic panel, but I don't have one so don't know how fragile/robust they are.
Hair dryer heat will be fine on any panel, it will be less hot than siting your car in the sun on a hot day.
I used one frequently to remove body wraps quite successfully, it may leave some glue residue but an alcohol wipe or sticky stuff remover will finish that off. And when I say hair dryer I don’t mean a heat gun which can get you into trouble If I’m not on a bike it’s because only a 4x4 will do… 2011 2.4 Puma 90 HT Last edited by Leamreject on 24th Sep 2022 1:21pm. Edited 1 time in total |
^^^ Good point and an important distinction, a hairdryer certainly won't do any harm.
My brain was saying "heat gun" when everyone had written "hairdryer". |
I don’t own a hair dryer for reasons that would be obvious if you saw me, but someone I know does…
I have used it to remove decals from numerous vehicles without any problem. Any adhesive residue can be removed with a panel wipe or white spirit. I used this method to remove the Defender decal from my plastic air con grill surround with no issues. I wouldn’t use a heat gun on my hair…but then again I haven’t got any… |
