Home > Maintenance & Modifications > Bilstein and springs
eutek
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Hi all...
I've been doing some research on the forum regarding dampers, specifically Bilsteins, and springs. We do 95% motorway driving with the Defender and occassional, incidental off-roading - nothing extreme.
It's main, intended use was to ferry us back and forth to Eastern Europe - on the way out it is usually heavily loaded (again, nothing extreme - not pushing design limits) however on the way back it is nearly empty save for some luggage and occupants.
I've got to tame the bucking and bouncing and I read that someone used Bilstein B46-0243 on the front and B46 0253 on the rear with great effect.
Supposedly these are direct replacements for the LR dampers. I assume that the Bilsteins offer better performance than the stock ones, i.e. they're not a like-for-like replacement?
There is also a thread where part numbers "625670020" and "625530030" are mentioned - but I can't find these anywhere. Are these the same dampers?
Also - can anyone recommend replacement springs? The ride in the back is very harsh unless I am carrying loads of stuff... and even then it is still bouncy.
I've tried different tyre pressures, and this has a minimal effect.
Lastly... would polybushes make any difference to the ride?
Post #91727 28th Sep 2011 8:49am
K9F
Eutek,
I'm not 100% sure but XS models such as yours (and mine) used to come with 'HD' - Heavy Duty springs advertised as standard fit. Maybe you would be better off downgrading to whatever is classed as standard or an equivalent?
Sorry I cannot be more precise! Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #91732 28th Sep 2011 10:03am
MK
How about adjustable Koni heavy track direct replacement? (not Heavy track raid) Puma 110" SW
Post #91735 28th Sep 2011 10:37am
Honker
 2014 Defender 110 Puma 2.2 XS CSW Corris Grey
Ive been looking at a similar thing as I find the unladen ride too stiff and punchy. The rear springs appear to be 225lb ( fronts 175lb) so I'm wondering if a bespoke rear set could be the solution along with the uprated shocks. I'm going to have a chat with extreme 4x4 who seem to make bespoke springs and try softer rate , or a more progressive rate. Will let you know what happens!
Stu
Post #91754 28th Sep 2011 12:30pm
landy andy
Agree with the Koni they are great dampers, and are adjustable, and that could be the key for you..
Honker, why would you want to talk to extreme! They are trouble, (scorpion before). If you have suspension questions I would talk to Devon 4x4, or but better is Gwyn Lewis.
Andy
Post #91780 28th Sep 2011 5:25pm
Honker
Andy
Hi Andy, thanks for the tip! I'll have a chat with the others first Thumbs Up
Stu
Post #91788 28th Sep 2011 6:26pm
bob neville
You could also try Flatdog - they do springs for 90's.
Bob
Post #91792 28th Sep 2011 7:02pm
Honker
Bob
Ta, I'll give them a buzz too !
Stu
Post #91798 28th Sep 2011 7:37pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
i 'sorted' my 90 XS by putting standard LR road springs on the rear and Koni heavy track shocks all round.
it has mad a huge difference and it will still carry a heavy load when needed or just me.
search the forum there are many posts on this subject.
standard vs HD spring info:
90 4 seat station wagon (2400 Kg) - NOW
Front - Driver's side REB500200 Red/green/white
Front - Passenger side REB500220 Red/green/orange
Rear - Driver's side RKB500290 Red/green/green
Rear - Passenger side RKB500280 Red/green/red
90 4 seat station wagon (2550 Kg) - ORIGINAL FIT
Rear - Driver's side RKB500270 White/green/pink
Rear - Passenger side RKB500310 White/green/purple BM52
Post #91799 28th Sep 2011 7:47pm
MK
LR applications from 2751 to 2779 (except 2768). Note the specs for rear 110"s
 Puma 110" SW
Post #91811 28th Sep 2011 8:54pm
Honker
bm52 and MK, thanks most useful Thumbs Up
Stu
Post #91813 28th Sep 2011 9:00pm
Alive Tuning
We can make bespoke spring sets, and supply various bilstein options. Give us a call on 01472 812900, and ask to speak to Toby. He's our in house suspension/handling guru, and will have the answers your looking for.
Maybe some forum discount too? Wink
Post #92261 1st Oct 2011 8:53pm
