![]() | Home > Maintenance & Modifications > Bilstein and springs |
Eutek,
I'm not 100% sure but XS models such as yours (and mine) used to come with 'HD' - Heavy Duty springs advertised as standard fit. Maybe you would be better off downgrading to whatever is classed as standard or an equivalent? Sorry I cannot be more precise! ![]() Treat every day as if it is your last....one day you will be right!! |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2489 ![]() ![]() ![]() |
How about adjustable Koni heavy track direct replacement? (not Heavy track raid) Puma 110" SW
Honker Member Since: 26 Jun 2011 Location: St Albans Posts: 353 ![]() ![]() ![]() |
Ive been looking at a similar thing as I find the unladen ride too stiff and punchy. The rear springs appear to be 225lb ( fronts 175lb) so I'm wondering if a bespoke rear set could be the solution along with the uprated shocks. I'm going to have a chat with extreme 4x4 who seem to make bespoke springs and try softer rate , or a more progressive rate. Will let you know what happens!
Stu |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5986 ![]() ![]() |
Agree with the Koni they are great dampers, and are adjustable, and that could be the key for you..
Honker, why would you want to talk to extreme! They are trouble, (scorpion before). If you have suspension questions I would talk to Devon 4x4, or but better is Gwyn Lewis. Andy |
Hi Andy, thanks for the tip! I'll have a chat with the others first ![]() Stu |
You could also try Flatdog - they do springs for 90's.
Bob |
Ta, I'll give them a buzz too ! Stu |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 ![]() ![]() ![]() |
i 'sorted' my 90 XS by putting standard LR road springs on the rear and Koni heavy track shocks all round.
it has mad a huge difference and it will still carry a heavy load when needed or just me. search the forum there are many posts on this subject. standard vs HD spring info: 90 4 seat station wagon (2400 Kg) - NOW Front - Driver's side REB500200 Red/green/white Front - Passenger side REB500220 Red/green/orange Rear - Driver's side RKB500290 Red/green/green Rear - Passenger side RKB500280 Red/green/red 90 4 seat station wagon (2550 Kg) - ORIGINAL FIT Front - Driver's side REB500200 Red/green/white Front - Passenger side REB500220 Red/green/orange Rear - Driver's side RKB500270 White/green/pink Rear - Passenger side RKB500310 White/green/purple BM52 |
LR applications from 2751 to 2779 (except 2768). Note the specs for rear 110"s
![]() Click image to enlarge Puma 110" SW ............................................................. Earth first. Other planets later |
bm52 and MK, thanks most useful
![]() Stu |
Alive Tuning Member Since: 01 Mar 2010 Location: Louth Posts: 610 ![]() ![]() |
We can make bespoke spring sets, and supply various bilstein options. Give us a call on 01472 812900, and ask to speak to Toby. He's our in house suspension/handling guru, and will have the answers your looking for.
Maybe some forum discount too? ![]() |
