Home > Puma (Tdci) > Rear window latches
Vitesse
Rear window latches
Hi. I am trying to remove the outer rear window latch trim in order to repaint. It appears to be tricky to remove. Is it bonded on or double sided tape?? Anyone know please 🙏 2015 90 XS Santorini Black
Post #948018 4th Apr 2022 5:18pm
Dinnu
They are screwed from the inside. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #948023 4th Apr 2022 5:54pm
PCM
I think if it's the latch i'm thinking about you remove the Phillips screw that hold the inside part, remove the inside part to reveal the Phillips screw that hold the outside part, remove the screw and you should be sorted...
Or get a set of these puppies...
https://www.optimill-uk.com/sliding-window-catch-covers.html
Cheating I know...
Post #948024 4th Apr 2022 5:54pm
Vitesse
Thanks. Yes the screws are removed but the catch isn’t coming out of the glass. Not sure if it is bonded or just a bit stuck with time. Didn’t want to pry and damage the glass. 🙏 2015 90 XS Santorini Black
Post #948042 4th Apr 2022 8:01pm
Dinnu
Perhaps they are simply stuck with time.
You could post a picture of what you see from the inside to be 100% sure. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #948097 5th Apr 2022 2:33am
Vitesse
Thanks. I have it all put back together now but can get some pics later today.
I am thinking it’s just stuck over time and possibly is a gasket or something 👍 2015 90 XS Santorini Black
Post #948116 5th Apr 2022 7:43am
Vitesse
Cheating I know...
Thumbs Up Thanks for the link 2015 90 XS Santorini Black
Post #948117 5th Apr 2022 7:44am
