![]() | Home > Puma (Tdci) > Rear window latches |
| Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3649
They are screwed from the inside. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
| PCM Member Since: 25 Jan 2019 Location: North East Posts: 895
I think if it's the latch i'm thinking about you remove the Phillips screw that hold the inside part, remove the inside part to reveal the Phillips screw that hold the outside part, remove the screw and you should be sorted...
Or get a set of these puppies... https://www.optimill-uk.com/sliding-window-catch-covers.html Cheating I know... |
| Vitesse Member Since: 21 Mar 2014 Location: Sussex Posts: 409
Thanks. Yes the screws are removed but the catch isn’t coming out of the glass. Not sure if it is bonded or just a bit stuck with time. Didn’t want to pry and damage the glass. 🙏 2015 90 XS Santorini Black
Perhaps they are simply stuck with time.
You could post a picture of what you see from the inside to be 100% sure. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
Thanks. I have it all put back together now but can get some pics later today.
I am thinking it’s just stuck over time and possibly is a gasket or something 👍 2015 90 XS Santorini Black |
| All times are GMT |
