![]() | Home > Maintenance & Modifications > LT230 blind hole crack |
Angus_Beef Member Since: 30 Apr 2015 Location: Oslo Posts: 434 ![]() ![]() ![]() |
Grüezi Marc
That's unfortunate. Personally, I would be inclined to replace that case with a sleeved one from Ashcroft. They are only £85 plus a £100 core charge. Cheers Dave Roaming around 🇳🇴🇨🇭 |
pistonfields Member Since: 29 Mar 2022 Location: Zurich Posts: 76 ![]() ![]() |
Thanks for your reply. Yes that is indeed a good option. I wanted to sleeve the case myself as it's a fun task, but now with the cracked holes it's a different story. I might look into that but would still like to know if some of you just ignored it and had no problems so far...
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2303 ![]() ![]() ![]() |
Hello pistonfields ... and welcome
![]() TIG welding Cast Aluminium Alloy often only postpones the inevitable... ![]() I agree with Angus_Beef replace the component and put the past bad workmanship behind you. The effort to get to this area and rebuild the Transmission generally makes any 'not best practice' a false economy... (IMO) Good Luck SKIP https://www.defender2.net/forum/topic83242.html |
Linds Hanson Member Since: 16 Jan 2021 Location: Cornwall Posts: 524 ![]() ![]() |
Probably best to fit Wurth threadserts with locktite
I have now ordered a replacement housing to fix the transfer case as son as possible. I might try to weld the cracked case just for fun at some point in life
![]() thanks again for your help! |
