Home > Maintenance & Modifications > LT230 blind hole crack
pistonfields
Switzerland
Hi there!
I'm rebuilding my transfer case. Boy, the previous owner / mechanic did a poor job. It's a mess. Big Cry
As visible in the pictures two blind holes have cracked due to hydrolock. They have put sealant inside the holes... good job, must have been a professional. I wonder why they used screws at all, as everything was glued together with tons of sealant.
I'm about to check if the threads are still tight enough to hold the bolt properly but would like to know from you guys what to do next. Just leave it as it is (if the bolts do not wiggle) or get it welded? I have an AC TIG welder but do not plan on do that with TIG / by myself. I have welded cast aluminium in the past but know that it will crack again due to stress - at least with my level of skill. I plan on sleeving the case so I have to do some mill work anyway; the project is taking longer than I thought. As usual... Honestly I'm happy if I can keep work to a minimum.
Cheers from Switzerland,
Marc
Post #947380 29th Mar 2022 8:29am
Angus_Beef
Norway 2015 Defender 110 Puma 2.2 SW Corris Grey
Grüezi Marc
That's unfortunate. Personally, I would be inclined to replace that case with a sleeved one from Ashcroft. They are only £85 plus a £100 core charge.
Dave Roaming around 🇳🇴🇨🇭
Post #947382 29th Mar 2022 8:44am
pistonfields
Switzerland
Thanks for your reply. Yes that is indeed a good option. I wanted to sleeve the case myself as it's a fun task, but now with the cracked holes it's a different story. I might look into that but would still like to know if some of you just ignored it and had no problems so far...
Post #947388 29th Mar 2022 9:19am
X4SKP
Hello pistonfields ... and welcome Thumbs Up
TIG welding Cast Aluminium Alloy often only postpones the inevitable... Crying or Very sad
I agree with Angus_Beef replace the component and put the past bad workmanship behind you.
The effort to get to this area and rebuild the Transmission generally makes any 'not best practice'
a false economy... (IMO)
Good Luck SKIP
Post #947390 29th Mar 2022 9:58am
Linds Hanson
Probably best to fit Wurth threadserts with locktite
Post #947391 29th Mar 2022 9:59am
pistonfields
Switzerland
I have now ordered a replacement housing to fix the transfer case as son as possible. I might try to weld the cracked case just for fun at some point in life Laughing
thanks again for your help!
Post #947689 1st Apr 2022 10:52am
