Home > Puma (Tdci) > mt82 output shaft advice
Sam smith
United Kingdom 2009 Defender 110 Puma 2.4 HT Epsom Green
hello
wondering if anyone is able to offer me some advice with my output shaft. as my gearbox is off the defender already i thought i better take a look to see what its like as ive heard it can be a common issue with them. the truck has only done around 70k miles. the output shaft had obviously been fitted dry by the factory so there was some very light surface rust (spent 90% of its time in a dry climate).
i was wondering if it is really worth the hassle and cost of replacing it when it looks good to me very minimal wear. i would change the snap ring and use the recommended antisieze. is this a bad idea?
cheers
Post #941501 7th Feb 2022 10:43pm
LR90XS2011
https://www.defender2.net/forum/topic62521...ft+failure
all the info you need above DEFENDER 90 TDCI XS,
Post #941502 7th Feb 2022 10:59pm
If after cleaning up it really is a good tight fit with negligible wear, the only reason to replace it would be if you were fitting one of the upgraded solutions. On a vehicle with 70k miles and no wear, if it is in genuinely good condition (and not having seen it I cannot judge) then I would not replace it, but would make sure to lubricate it copiously on assembly.
Personally I would not use the factory-spec anti-seize (which I believe to be a form of Weicon paste) since I don't think anti-seize is appropriate for this "problem" but would instead use a high-quality molybdenum disulphide grease (a good CV-joint grease, for example).
Post #941512 8th Feb 2022 12:24am
Sam smith
Ok thank for the feedback it is very much appreciated. I have tried to attach some photos
I think they’re in my gallery
Post #941699 8th Feb 2022 8:13pm
MK
Pictures show the pieces in very good shape. Beside the grease make sure the snap ring fit is in really tight. Puma 110" SW
Post #941793 9th Feb 2022 3:58pm
JOW240725
Having had three output shafts within the first 50k miles, I would normally say replace it while its out. But it does look in good condition, I think i'd worry the replacement might be worse!
Your photos:-
 James
Instagram @suffolk_rovers
Post #941801 9th Feb 2022 5:31pm
Sam smith
Ok thank you very much yes that was one of my concerns and I don’t really want to pay the extra for one of the updated ones that have been made by a couple of companies.
Thank you for putting the photos on there as well
I will replace snap ring and hope for the best then
Post #941823 9th Feb 2022 7:35pm
lonewolf
United Kingdom 2010 Defender 90 Puma 2.4 CSW Zambezi Silver
What you save on not replacing the output shaft, as it looks in very good condition, you could invest in a new tyre 😂 (that’s if it’s one of yours that is?)
Post #942599 15th Feb 2022 5:28pm
Sam smith
That’s one of the better ones believe it or not
Post #942614 15th Feb 2022 7:02pm
lonewolf
Post #942671 16th Feb 2022 9:40am
