![]() | Home > Puma (Tdci) > mt82 output shaft advice |
Sam smith Member Since: 12 Aug 2021 Location: Suffolk Posts: 79 ![]() ![]() ![]() |
hello
wondering if anyone is able to offer me some advice with my output shaft. as my gearbox is off the defender already i thought i better take a look to see what its like as ive heard it can be a common issue with them. the truck has only done around 70k miles. the output shaft had obviously been fitted dry by the factory so there was some very light surface rust (spent 90% of its time in a dry climate). i was wondering if it is really worth the hassle and cost of replacing it when it looks good to me very minimal wear. i would change the snap ring and use the recommended antisieze. is this a bad idea? cheers |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3674 ![]() ![]() ![]() |
https://www.defender2.net/forum/topic62521...ft+failure
all the info you need above DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
Ok thank for the feedback it is very much appreciated. I have tried to attach some photos
I think they’re in my gallery |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2478 ![]() ![]() ![]() |
Pictures show the pieces in very good shape. Beside the grease make sure the snap ring fit is in really tight. Puma 110" SW
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7928 ![]() ![]() ![]() |
Having had three output shafts within the first 50k miles, I would normally say replace it while its out. But it does look in good condition, I think i'd worry the replacement might be worse!
Your photos:- ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge James MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
Ok thank you very much yes that was one of my concerns and I don’t really want to pay the extra for one of the updated ones that have been made by a couple of companies.
Thank you for putting the photos on there as well I will replace snap ring and hope for the best then |
lonewolf Member Since: 23 Oct 2013 Location: North East England Posts: 210 ![]() ![]() ![]() |
What you save on not replacing the output shaft, as it looks in very good condition, you could invest in a new tyre 😂 (that’s if it’s one of yours that is?)
That’s one of the better ones believe it or not
