Home > Maintenance & Modifications > Fitting IC without touching AC
stephan123
I've taken delivery of a late xmas present in the form of an uprated intercooler and I'm keen to fit it myself. However, I've read that the aircon system (which my car has) must first be depressurised. I don't want to mess around with the AC and wandered if anyone has fitted an IC without doing so. Many thanks
Post #936458 5th Jan 2022 4:58pm
bankz5152
On a TD5 Defender anyway, makes it a easier but you dont have to. Just requires a lot of wiggling aroud to fit it in. Especially with the hoses.
Makes it easier to move the rad back as well so its all loose, you can also move the AC rad around to get more space just be careful.
Post #936466 5th Jan 2022 5:34pm
jpboost
United Kingdom 2014 Defender 110 Puma 2.2 SW Keswick Green
I don't know which model you have,
but on the TDCI Puma's you can change the intercooler without touching the aircon. Mine was done earlier this year, and it looked fairly straightforward.
Post #936468 5th Jan 2022 5:45pm
hank
I've done it twice. It's tight but will go with enough perseverance and wiggling.
Remember to cut the plastic lugs or you'll be there forever - ask me how I know... https://www.defender2.net/forum/topic67250.html > 110 XS Double Cab
Post #936499 5th Jan 2022 8:51pm
Dinnu
View of front end of a Puma with slam panel and a few more bracketry removed.
 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #936507 5th Jan 2022 9:09pm
