Home > Maintenance & Modifications > Intercooler Fitting Musings. Radiator lugs need trimming?
hank
Sat at work reminiscing about the day I fitted an Allisport intercooler to my TDCi Big Cry
To cut a long story short, it would not fit. It had a hell of a wonk on and would not sit plumb meaning that the plugs would not locate in their sockets. This was caused by the allisport intercooler fouling two plastic lugs; one either side of the radiator which I had to cut off (shown red below)
I have not seen anybody else report this, has anybody else experienced it? Hope the intercooler doesn't split now as others have experienced as it's not a job I fancy doing again
 > 110 XS Double Cab
Post #769981 25th Apr 2019 10:54am
williamthedog
2011 Defender 90 Puma 2.4 PU Tamar Blue
Yes I had to trim off the lugs on the radiator to allow the intercooler to sit properly. I found it relatively easy to fit but I haven't got air con on mine. I'm sure the instructions that came with the intercooler said about trimming the lugs off also about spacers on the slam panel support bars. Thumbs Up
Post #769993 25th Apr 2019 12:04pm
