![]() | Home > Maintenance & Modifications > Fitting IC without touching AC |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2239 ![]() ![]() ![]() |
On a TD5 Defender anyway, makes it a easier but you dont have to. Just requires a lot of wiggling aroud to fit it in. Especially with the hoses.
Makes it easier to move the rad back as well so its all loose, you can also move the AC rad around to get more space just be careful. |
jpboost Member Since: 13 Apr 2021 Location: Gatwick Posts: 380 ![]() ![]() ![]() |
I don't know which model you have,
but on the TDCI Puma's you can change the intercooler without touching the aircon. Mine was done earlier this year, and it looked fairly straightforward. |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2363 ![]() ![]() ![]() |
I've done it twice. It's tight but will go with enough perseverance and wiggling.
Remember to cut the plastic lugs or you'll be there forever - ask me how I know... https://www.defender2.net/forum/topic67250.html > 110 XS Double Cab |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3642 ![]() ![]() ![]() |
View of front end of a Puma with slam panel and a few more bracketry removed.
![]() Click image to enlarge 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
