Home > Puma (Tdci) > Puma replacement clock - rare as hen's teeth?
Page 2 of 2 <12
Race.it
Spain 2010 Defender 110 Puma 2.4 SW Alaska White
My bad did not see the .es site Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details
Post #967273 10th Oct 2022 7:26pm
Bleecker83
France 2008 Defender 90 Puma 2.4 SVX Soft Top Santorini Black
Hi Race
i did not use bearmarch , i ordered on JLR website. But it seems to be online and ok ?
(yes, .es ...)
As for the Recaro, hopefully they (JLR) have it Wink.
At least, i have 2 recaro's in my Def (90 SVX STop 60th anniv.), what's more heated seats Smile)
(Originally mounted).
Maybe some others Def were delivered with Recaro's...?
Marco
Post #967305 11th Oct 2022 7:53am
Race.it
Hi Marco, I have just done the same as you and ordered from JLR direct, (just incase, as my clock works kind of but as a spare Smile )
I would of used bear mach.es no probs, but sometimes they tell me not in stock, after its in stock on website (not the first time I had this) Searching for my first Defender...and started just as Covid hit, so talk about timing.
Post #967311 11th Oct 2022 9:32am
Race.it
This is a first 😱 Searching for my first Defender...and started just as Covid hit, so talk about timing.
Post #967316 11th Oct 2022 10:16am
Dinnu
Maybe that is to set the time zone on your analogue clock Rolling with laughter
Inform them if your country had the daylight saving Rolling with laughter 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #967319 11th Oct 2022 10:31am
Race.it
They got back to me due to short supply they are restricting the clocks to only people that have the correct vehicle. Searching for my first Defender...and started just as Covid hit, so talk about timing.
Post #967331 11th Oct 2022 12:36pm
Martin
Site Admin
Always been the case for most parts for Limited Edition vehicles.
You could always give them a VIN Whistle  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #967337 11th Oct 2022 1:34pm
Race.it
Did not think the std clock was limited edition Searching for my first Defender...and started just as Covid hit, so talk about timing.
Post #967339 11th Oct 2022 2:02pm
Martin
Site Admin
LR069025 is LE clock (Heritage/Adventure)
YFB500030PUY is standard clock  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #967340 11th Oct 2022 2:12pm
Pacha
Bearmach closed down last month. Rgds.
Chris
Post #967341 11th Oct 2022 2:45pm
Race.it
This is not the uk bear Mach they just use the name it’s a 4x4 shop in northern spain Searching for my first Defender...and started just as Covid hit, so talk about timing.
Post #967350 11th Oct 2022 4:03pm
Race.it
Ah that I did not know, they have accepted my chassis number is there anything different on the clock? Or just different part numbers. Searching for my first Defender...and started just as Covid hit, so talk about timing.
Post #967356 11th Oct 2022 5:08pm
Martin
Site Admin
LE clock has an aluminium bezel I think  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #967357 11th Oct 2022 5:21pm
Bleecker83
Happy my post may have help you Wink
I received my new clock yesterday, indeed it's in aluminium.
(It should fit perfectly in my Def Thumbs Up )
In case you still want black one, i think you can unmount / change aluminium bezel quite easily ...
(They also asked me my VIN...)
Post #967461 12th Oct 2022 5:07pm
Page 2 of 2 <12
