![]() | Home > Puma (Tdci) > Puma replacement clock - rare as hen's teeth? |
Race.it Member Since: 27 Aug 2019 Location: Algeciras Posts: 845 ![]() ![]() ![]() |
My bad did not see the .es site Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details |
Hi Marco, I have just done the same as you and ordered from JLR direct, (just incase, as my clock works kind of but as a spare
![]() I would of used bear mach.es no probs, but sometimes they tell me not in stock, after its in stock on website (not the first time I had this) Searching for my first Defender...and started just as Covid hit, so talk about timing. 5 months after starting the search I found it, and here is the details |
![]() This is a first 😱 Searching for my first Defender...and started just as Covid hit, so talk about timing. 5 months after starting the search I found it, and here is the details |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3646 ![]() ![]() ![]() |
Maybe that is to set the time zone on your analogue clock
![]() Inform them if your country had the daylight saving ![]() 2012 90 CSW, 2.2TDCI, Santorini Black |
They got back to me due to short supply they are restricting the clocks to only people that have the correct vehicle. Searching for my first Defender...and started just as Covid hit, so talk about timing.
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6726 ![]() ![]() ![]() |
Always been the case for most parts for Limited Edition vehicles.
You could always give them a VIN ![]() ![]() ![]() |
Did not think the std clock was limited edition Searching for my first Defender...and started just as Covid hit, so talk about timing.
LR069025 is LE clock (Heritage/Adventure)
YFB500030PUY is standard clock ![]() ![]() |
Pacha Member Since: 23 Feb 2020 Location: North Yorkshire Posts: 781 ![]() ![]() ![]() |
Bearmach closed down last month. Rgds. Chris |
This is not the uk bear Mach they just use the name it’s a 4x4 shop in northern spain Searching for my first Defender...and started just as Covid hit, so talk about timing.
Ah that I did not know, they have accepted my chassis number is there anything different on the clock? Or just different part numbers. Searching for my first Defender...and started just as Covid hit, so talk about timing. 5 months after starting the search I found it, and here is the details |
LE clock has an aluminium bezel I think
Bleecker83 Member Since: 10 Oct 2022 Location: PACA Var Posts: 3 ![]() ![]() ![]() |
Happy my post may have help you ![]() I received my new clock yesterday, indeed it's in aluminium. (It should fit perfectly in my Def ![]() In case you still want black one, i think you can unmount / change aluminium bezel quite easily ... (They also asked me my VIN...) |
