Home > Maintenance & Modifications > landreiziger loom & sidelights |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2200 |
Have you disabled the dim-dip system on the original wiring?
Steve 02' 110 TD5 Double Cab Rebuild Thread 84' 90 3.9 V8 Caged Pickup Build Thread - Now For Sale |
29th Nov 2021 9:27am |
donmacn Member Since: 07 Nov 2017 Location: Nth Scotland Posts: 1829 |
If your lighting loom was standard spec to begin with, then I’m pretty sure that won’t be a fault of the Landreiziger kit.
I had disabled the dim dip prior to fitting it, so that’s something I didn’t have to contend with. Martin (at Landreiziger) is a very helpful guy though. If you don’t find a fix, send him an email. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
29th Nov 2021 9:32am |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5743 |
Nope. But, with the old head lights I used to have side lights and dim headlights then that stopped working. Never sussed why. But now you mention it, I wonder if a small amount of voltage is getting to the relays and that is causing the issue? Disable via the relay or the dim-dip resistor under the wing? 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
29th Nov 2021 10:04am |
Yeah that will be the issue then. I would just unplug the inner wing resistor and that should sort it
Cheers, Steve 02' 110 TD5 Double Cab Rebuild Thread 84' 90 3.9 V8 Caged Pickup Build Thread - Now For Sale |
29th Nov 2021 10:42am |
Sound. I was sat on the train(avoiding the train nutter) and pondering if the dim-dip could cause the issue. 1999 Defender TD5 110
29th Nov 2021 11:30am |
Unplugged the dim dip relay and issue resolved. Cheers all. 1999 Defender TD5 110
14th Dec 2021 2:57pm |
Mossberg Member Since: 29 Feb 2020 Location: Lancs Posts: 552 |
https://m.facebook.com/story.php?story_fbi...8&_rdr |
14th Dec 2021 4:42pm |
Its been a long time since i've seen that sketch. For me it was the train nutter accusing me of stealing his mums medicine ! 1999 Defender TD5 110
14th Dec 2021 4:50pm |
