Home > Maintenance & Modifications > landreiziger loom & sidelights
excossack
Since fitting the landreiziger loom I am now no longer able to have just side lights on without having normal driving lights on as well.
A wiring issue or a feature of the landreiziger upgrade loom?
With the ignition off, i get side lights as i used to. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #931636 29th Nov 2021 7:53am
rallysteve
Have you disabled the dim-dip system on the original wiring?
Post #931650 29th Nov 2021 9:27am
donmacn
If your lighting loom was standard spec to begin with, then I’m pretty sure that won’t be a fault of the Landreiziger kit.
I had disabled the dim dip prior to fitting it, so that’s something I didn’t have to contend with.
Martin (at Landreiziger) is a very helpful guy though. If you don’t find a fix, send him an email. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #931651 29th Nov 2021 9:32am
excossack
Steve
Nope. But, with the old head lights I used to have side lights and dim headlights then that stopped working. Never sussed why.
But now you mention it, I wonder if a small amount of voltage is getting to the relays and that is causing the issue?
Disable via the relay or the dim-dip resistor under the wing? 1999 Defender TD5 110
Regards
John M0VAZ
Post #931658 29th Nov 2021 10:04am
rallysteve
Yeah that will be the issue then. I would just unplug the inner wing resistor and that should sort it Thumbs Up
Cheers,
Post #931664 29th Nov 2021 10:42am
excossack
Sound. I was sat on the train(avoiding the train nutter) and pondering if the dim-dip could cause the issue. 1999 Defender TD5 110
Regards
John M0VAZ
Post #931668 29th Nov 2021 11:30am
excossack
Unplugged the dim dip relay and issue resolved. Cheers all. 1999 Defender TD5 110
Regards
John M0VAZ
Post #933555 14th Dec 2021 2:57pm
Mossberg
United Kingdom 1993 Defender 90 300 Tdi HT Aintree Green
https://m.facebook.com/story.php?story_fbi...8&_rdr
Post #933570 14th Dec 2021 4:42pm
excossack
Its been a long time since i've seen that sketch. For me it was the train nutter accusing me of stealing his mums medicine ! 1999 Defender TD5 110
Regards
John M0VAZ
Post #933571 14th Dec 2021 4:50pm
