Home > Technical > What’s this well hidden under steering column
ericvv
Good morning,
For the first time noticed something well hidden under the steering column shroud. You cannot reach it with your hands as space is too tight. It is something meant to be there as the little circular hole is nicely finished. Difficult to see, but seems something circular with two little metallic points and one or more electric wires. The first picture shows the best detail, the other two are more of an overview. Any idea?
Eric
 You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #918274 23rd Aug 2021 7:57am
X4SKP
Hello ericvv
It's a small location 'Boss' that stays in place when you remove the lower instrument (Stalks) cover.
Yours looks to have an internal wire that has been semi pulled through / trapped, which would be worth
freeing up. Its all a bit tight on a Puma but with the rubber tray mat out and then working your way round
the fixing screws it easy enough. When the cover is off you will see the intention of this 'little feature'.
Good Luck SKIP
Post #918280 23rd Aug 2021 8:19am
ericvv
Thanks for the explanation Skip,
As everything is working as it should, I think I’m just going to leave it alone and not create potential problems by toying around in this tight space. Laughing
Post #918297 23rd Aug 2021 9:54am
chek
Switzerland 2016 Defender 90 Puma 2.2 SW Havana
Leaving it as it is will decrease the value of your defender by at least 50-75%. On the other hand, the truck immediately will start to corrode badly as soon as that wire is put back in place...Wink
Post #918313 23rd Aug 2021 11:58am
X4SKP
My guess is that it's a stray wire from one of the Steering Column Stalks...
The Location Boss Visible here...
 SKIP
Post #918340 23rd Aug 2021 3:29pm
LR90XS2011
I would loosen the cowl screws and push the wire back in the hole DEFENDER 90 TDCI XS,
Post #918343 23rd Aug 2021 3:41pm
