![]() | Home > Technical > What’s this well hidden under steering column |
Good morning,
For the first time noticed something well hidden under the steering column shroud. You cannot reach it with your hands as space is too tight. It is something meant to be there as the little circular hole is nicely finished. Difficult to see, but seems something circular with two little metallic points and one or more electric wires. The first picture shows the best detail, the other two are more of an overview. Any idea? Eric ![]() Click image to enlarge ![]() Click image to enlarge You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2304 ![]() ![]() ![]() |
Hello ericvv
It's a small location 'Boss' that stays in place when you remove the lower instrument (Stalks) cover. Yours looks to have an internal wire that has been semi pulled through / trapped, which would be worth freeing up. Its all a bit tight on a Puma but with the rubber tray mat out and then working your way round the fixing screws it easy enough. When the cover is off you will see the intention of this 'little feature'. Good Luck SKIP https://www.defender2.net/forum/topic83242.html |
Thanks for the explanation Skip,
As everything is working as it should, I think I’m just going to leave it alone and not create potential problems by toying around in this tight space. ![]() Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
My guess is that it's a stray wire from one of the Steering Column Stalks...
The Location Boss Visible here... ![]() Click image to enlarge SKIP https://www.defender2.net/forum/topic83242.html |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3677 ![]() ![]() ![]() |
I would loosen the cowl screws and push the wire back in the hole DEFENDER 90 TDCI XS,
