![]() | Home > For Sale & Wanted > [For Sale] Defender Roof Bars |
Staftly Member Since: 06 Jul 2012 Location: Lancashire Posts: 55 ![]() ![]() ![]() |
For Sale : 3 x Galvanised Roof Bars, 150 quid. These were a collaboration between Mantec and Boab some years ago. There is information on this site about them here;
https://www.defender2.net/forum/topic8626....antec+boab Mine of course have been blasted then galved so should last forever. I had them on my 110 and attached a 6x4 trailer base board. Worked a treat for years and at a fraction of the cost of a roof rack. I simply drilled some lash points and I was away. The fixing brackets have not been galved (too small and fiddly evidently). I was planning to rub them down and paint with POR15 and a finish spray of galv spray. That way they will match the bars. Never got round to that, so you will need to do that yourself if you want them to look the part. The small bolt holes on the bars have a little crust from the galv so will need a clean up or tapping out slightly before fitting. You can buy similar new ones here https://www.masai4x4.com/defender/roof-rac...p202078114 at 95 quid a pop but its probably only a matter of time before they rust up. 150 for the three. Collection from Charnock Richard Service Station M6 J27. I can hold on to then if you are passing sometime soon. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge I also have side steps also been blasted & galved. All hardware is there, tread plate, fixing bars, end caps etc. The fixing bars have not been galved, so I would suggest rubbing down and treating with POR15. There is a ding in the underside of one step and some rubber missing from the inside of the tread plate (see picture), but this is not really noticeable once fitted. Was planning to paint them up and re-fit but just too busy. So 50 quid the lot. Cheap since they will last forever! Same applies pick up from M6 J27. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Thanks Steve |
Bump, need the space. 90 quid for the 3 roof bars and 20 quid for the side rails. Bargain!
Siwynne Member Since: 04 Nov 2016 Location: West lancs Posts: 615 ![]() ![]() |
Pm inbound
Both items now SOLD to Siwynne. Thanks
