![]() | Home > Maintenance & Modifications > CB Antenna Mount - crap SWR readings |
CFB Member Since: 13 Sep 2007 Location: Bradford, West Yorkshire Posts: 803 ![]() ![]() |
Just fitted a body mount CB antenna above and right of the back door on the 110, properly earthed etc but can't get a decent SWR reading for love nor money. Checked with a meter and there is no short on the co-ax or mount so I'm baffled. Not had an issue on Defenders before.
Any ideas? Andy |
pom Member Since: 01 Jun 2010 Location: Worcester Posts: 1343 ![]() |
how you powering the cb, did you run the earth to the battery ?
Pom |
Just from the 12v cig lighter socket Andy
So will going straight to the battery help???? Andy
Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3472 ![]() ![]() ![]() |
Double check the mount is earthed, the co-ax isn't pinched and that the PL-259 is properly secured / soldered.
PS: Check your patch cable is still ok too. Steve. Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
Definitely no shorts anywhere, will run rig power direct to battery and see if that improves it. Andy
Landie Boy Member Since: 15 Jan 2011 Location: Essex Posts: 431 ![]() ![]() ![]() |
Hi, where have u earthed it to? Using a circuit tester, check the connection between the earth position and the battery.
Jack |
Aerial mount is earthed to the body and is a good strong earth, rig is on a 12v plug to cig lighter dash socket. Andy
hmmm, the aluminium body does not always give a strong earth...
Jack |
RobKeay Member Since: 19 Jul 2009 Location: Stafford Posts: 1596 ![]() ![]() ![]() |
I did two things brought a better aerial and earthed the bracket to the battery. Now I can get 6 miles coverage.
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 ![]() ![]() ![]() |
Question... Is it a tuned antenna? If not you will need to do that too.
Glyn ![]() ![]() |
All this reminds me of when I was installing CB's for people back in the early 80's
![]() Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 982 ![]() ![]() |
Can you use a CB aerial, successfully, as a radio aerial?
Merlin |
Probably better than using an old coat hanger ![]() Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
Sorted, thanks for the tips.
Ran an earth from the aerial mount direct to the battery and connected the rig direct to battery too, SWR reading now around 2 which is not perfect but much better. Andy |
