Home > Maintenance & Modifications > CB Antenna Mount - crap SWR readings
Page 1 of 3 123>
CFB
Just fitted a body mount CB antenna above and right of the back door on the 110, properly earthed etc but can't get a decent SWR reading for love nor money. Checked with a meter and there is no short on the co-ax or mount so I'm baffled. Not had an issue on Defenders before.
Any ideas? Andy
Post #85283 19th Aug 2011 8:36pm
pom
how you powering the cb, did you run the earth to the battery ?
Pom
Post #85285 19th Aug 2011 8:39pm
CFB
Just from the 12v cig lighter socket Andy
Post #85286 19th Aug 2011 8:40pm
CFB
So will going straight to the battery help???? Andy
Post #85287 19th Aug 2011 8:56pm
Happyoldgit
Double check the mount is earthed, the co-ax isn't pinched and that the PL-259 is properly secured / soldered.
PS: Check your patch cable is still ok too. Steve.
Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades.
Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone.
http://forums.lr4x4.com
Post #85289 19th Aug 2011 9:03pm
CFB
Definitely no shorts anywhere, will run rig power direct to battery and see if that improves it. Andy
Post #85292 19th Aug 2011 9:09pm
Landie Boy
United Kingdom 2010 Defender 110 Puma 2.4 USW Stornoway Grey
Hi, where have u earthed it to? Using a circuit tester, check the connection between the earth position and the battery.
Jack
Post #85297 19th Aug 2011 9:53pm
CFB
Aerial mount is earthed to the body and is a good strong earth, rig is on a 12v plug to cig lighter dash socket. Andy
Post #85304 19th Aug 2011 10:06pm
Landie Boy
hmmm, the aluminium body does not always give a strong earth...
Jack
Post #85319 19th Aug 2011 11:54pm
RobKeay
I did two things brought a better aerial and earthed the bracket to the battery. Now I can get 6 miles coverage.
Post #85326 20th Aug 2011 1:06am
Glynparry25
Question... Is it a tuned antenna? If not you will need to do that too.
Glyn Dog Sheep
Post #85339 20th Aug 2011 8:10am
Happyoldgit
All this reminds me of when I was installing CB's for people back in the early 80's Laughing Steve.
Post #85350 20th Aug 2011 11:06am
Merlin
Can you use a CB aerial, successfully, as a radio aerial?
Merlin
Post #85374 20th Aug 2011 4:26pm
Happyoldgit
Merlin
Probably better than using an old coat hanger Wink Steve.
Post #85375 20th Aug 2011 4:34pm
CFB
Sorted, thanks for the tips.
Ran an earth from the aerial mount direct to the battery and connected the rig direct to battery too, SWR reading now around 2 which is not perfect but much better. Andy
Post #85379 20th Aug 2011 5:11pm
Page 1 of 3 123>
