Home > Maintenance & Modifications > CB Antenna Mount - crap SWR readings
Page 2 of 3 <123>
landy andy
I use cb whip for my fm, but run it through a box of tricks so it works better
http://www.4x4cb.com/public/item.cfm?itemID=829
Andy
Post #85382 20th Aug 2011 5:59pm
Merlin
Great and thanks, I've just ordered one.
Merlin
Post #85410 20th Aug 2011 9:36pm
Merlin
Thanks Landy Andy, I've just fitted one of these and the wireless reception is soooo much better. I did need an aerial extension, which delayed the installation a bit. Here's a picture of the box fitted to the left of the CB radio:
Merlin
Post #86845 31st Aug 2011 3:16pm
4x4cb.com
Looking good there, Merlin!
Post #86854 31st Aug 2011 3:47pm
landy andy
Glad all is good Merlin.
Is that you Jim,
Are these units ok mounted outside in the elements. I have the older version and think it may need changing for a new one after a drowning in Wales.
Andy
Post #86857 31st Aug 2011 3:56pm
4x4cb.com
Hi Andy
Yup, 'tis Jim !
these aren't waterproof (as you've found out), but it might be worth taking the case off and running the guts under a tap (to remove any mud, sediment etc), and leaving it to dry in an airing cupboard for a few days.
It may just work again, although if its become corroded it may not.
The above can even work with cb's but you do need to act fast to prevent any corrosion!
Jim
Post #86866 31st Aug 2011 4:18pm
landy andy
Thanks for that Jim, will order a new one, and this time look after it.
Andy
Post #86868 31st Aug 2011 4:26pm
4x4cb.com
No probs Andy, i have a few in stock
Post #86889 31st Aug 2011 6:01pm
4x4cb.com
you're quick off the mark, Andy! be in the post tomorrow, hopefully with you on Friday
Post #86891 31st Aug 2011 6:07pm
landy andy
Thanks Jim, pleasure as always. Nice to see you on here, may be able to offer some help.
Is there a reason that a CB should be worse in the rain? Just got back from very wet Wales, and one of our group's CB was terrible whilst it was raining, but ok when not. Any ideas?
Andy
Post #86893 31st Aug 2011 6:22pm
4x4cb.com
sounds like he's probably got a problem with his mount or maybe more likely : cable.
if it lets water in, it'll probably throw the swr out and performance will go down the tubes but will be ok again when it dries up.
Possibly also that the water is shorting out the inner and outer of the cable, maybe in the plug or mount somewhere.
Whichever, the problem almost certainly lies in the cable or mount.
Post #86897 31st Aug 2011 6:35pm
bob neville
Hi Jim
Off Topic
Good talking to you this afternoon Thumbs Up
Looking forward to Friday but I get a feeling SWHMBO will have a long list of jobs for me this weekend so fitting may be slightly delayed Big Cry (well at least to Sunday)
Bob
Post #86899 31st Aug 2011 6:46pm
4x4cb.com
Hi Bob!
often the way... at least if you can do whats needed it gets her off your back for a bit, hopefully long enough to get the install done!
any questions just post on here, i can't promise an instant response but i do check emails etc during the day - even on a sunday!
speak soon
Jim
Post #86901 31st Aug 2011 6:51pm
4x4cb.com
Andy
your splitter has been posted today, first class, hopefully with you in the morning. If you're able to take some photos of it once you get it installed, i can put them on the site along with Merlins to really give people a good idea of where it can be put and how big it is etc.
I give away a £20 voucher every month for the best photos sent in : http://www.4x4cb.com/public/page.cfm?Page=651
Bob
Your kit is also on its way, sent by fedex, again will be there tomorrow - one box going to your work address. I'll PM you a tracking link so you can track its progress through Fedex's system. Again, check the link above for details of the voucher because the tti set is one i'm deffinately needing some photos of, so you've got a better chance than most of winning!
Thanks Gentlemen, any questions or problems, just ask!
Jim
Post #87071 1st Sep 2011 7:06pm
landy andy
Thanks Jim, all arrived as promised Bow down Thumbs Up Bow down
Much better than the old one. Might send it back under warranty, nothing lasts these days
Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter
Andy
Post #87566 4th Sep 2011 11:38am
Page 2 of 3 <123>
