![]() | Home > Maintenance & Modifications > Uprated front springs - reccomendations? |
CFB Member Since: 13 Sep 2007 Location: Bradford, West Yorkshire Posts: 803 ![]() ![]() |
I want to uprate the front springs slightly on the 110 to cope with the additional weight of the winch and bumper and also to bring the nose up a touch as it is currently quite low.
I don't want or need a full 2" lift kit and ideally I will need around 1" of lift only but most spring mfrs seem to only do standard or +2". So I'm considering the Terrafirma +2" ones but opting for 'light load' which I reckon might do the trick as the load will be a bit heavy for them so might not actually give the 2" lift. Either that or the 'medium load' vesrsion but don't want the front sitting higher than the rear for obvious reasons. Any thoughts?? Andy |
JSG Member Since: 12 Jul 2007 Location: Berkshire Posts: 2412 ![]() ![]() ![]() |
How about standard height heavy duty springs? John
http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
markalpha Member Since: 23 Apr 2008 Location: Downham Market Posts: 690 ![]() ![]() ![]() |
Landrover HD springs lifted my front by about 3/4-1".
Thanks folks, hadn't thought about O.E. HD springs, dealer supply only I guess? Andy
On further investigation it appears that standard 90 rear springs also serve as HD 110 fronts, seems bizarre but hey, a cheap solution! Andy
Try this site for spring info
![]() http://rovers.red90.ca/springinfo.html |
put a wanted up on here.
i did and got myself a set of hd springs |
Andy
I have just fitted a TF003AC winch bumper plus winch, 58kgs extra weight on the nose, and considered doing this myself. After being advised by my dealer that they did not think I would need hd springs on the front I did the following. With my First Four tubular bumper on I measured the distance from the centre of the front wheel to the bottom of the arch, took the bumper off and did the same, then fitted the new bumper, measured and finally the winch and measured. The TF bumper is considerably heavier than the FF one and the overall result is that my vehicle is sitting about 8mm lower at the front than it was with just the FF bumper on. I will probably stick with the standard springs for now. Bob |
Thanks Bob, I know the TF bumper + TDS winch will be heavier than the factory bumper and A-Bar so it's a bit of a given for me that I need to do something.
Looks like HD front (aka 90 rear) springs will be the best option I reckon ![]() |
If I change mine that is exactly what I am going to do. Britcar do them for a reasonable price.
Bob |
Part no's
NRC9448 , blue/red - drivers side NRC9449 , yellow/white - passenger side. Bob |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2490 ![]() ![]() ![]() |
You can also save some cash and fit either the RBC100111 rubberized shock tower ring or the ANR2938 spring isolator, both giving 10-12 mm of lift.
![]() ............................................................. Earth first. Other planets later |
Genuine parts are around £38 each, aftermarket around £15
Think I'll stick to genuine stuff. Andy |
