Home > Maintenance & Modifications > Uprated front springs - reccomendations?
CFB
I want to uprate the front springs slightly on the 110 to cope with the additional weight of the winch and bumper and also to bring the nose up a touch as it is currently quite low.
I don't want or need a full 2" lift kit and ideally I will need around 1" of lift only but most spring mfrs seem to only do standard or +2".
So I'm considering the Terrafirma +2" ones but opting for 'light load' which I reckon might do the trick as the load will be a bit heavy for them so might not actually give the 2" lift. Either that or the 'medium load' vesrsion but don't want the front sitting higher than the rear for obvious reasons.
Any thoughts?? Andy
Post #84847 17th Aug 2011 5:03pm
JSG
How about standard height heavy duty springs? John
2011 Tdci 110 CSW XS
Post #84848 17th Aug 2011 5:07pm
markalpha
England 2013 Defender 110 Puma 2.2 XS CSW Santorini Black
Landrover HD springs lifted my front by about 3/4-1".
Post #84850 17th Aug 2011 5:14pm
Glynparry25
If you want to just swap the fronts JSG has the perfect answer.
If you have a little cash to splash and want a full set of springs OME do a 1" lift. Also remember that some Pumas don't like lifting more than 1" without problems and others are fine (a bit hit or miss)
Glyn Dog Sheep
Post #84851 17th Aug 2011 5:16pm
CFB
Thanks folks, hadn't thought about O.E. HD springs, dealer supply only I guess? Andy
Post #84855 17th Aug 2011 5:37pm
CFB
On further investigation it appears that standard 90 rear springs also serve as HD 110 fronts, seems bizarre but hey, a cheap solution! Andy
Post #84883 17th Aug 2011 7:03pm
Lorryman100
Try this site for spring info Thumbs Up
http://rovers.red90.ca/springinfo.html
Post #84885 17th Aug 2011 7:06pm
T1G UP
put a wanted up on here.
i did and got myself a set of hd springs
Post #84888 17th Aug 2011 7:10pm
CFB
Thumbs Up Andy
Post #84900 17th Aug 2011 7:34pm
bob neville
Andy
I have just fitted a TF003AC winch bumper plus winch, 58kgs extra weight on the nose, and considered doing this myself.
After being advised by my dealer that they did not think I would need hd springs on the front I did the following.
With my First Four tubular bumper on I measured the distance from the centre of the front wheel to the bottom of the arch, took the bumper off and did the same, then fitted the new bumper, measured and finally the winch and measured.
The TF bumper is considerably heavier than the FF one and the overall result is that my vehicle is sitting about 8mm lower at the front than it was with just the FF bumper on.
I will probably stick with the standard springs for now.
Bob
Post #84984 18th Aug 2011 8:41am
CFB
Thanks Bob, I know the TF bumper + TDS winch will be heavier than the factory bumper and A-Bar so it's a bit of a given for me that I need to do something.
Looks like HD front (aka 90 rear) springs will be the best option I reckon Thumbs Up Andy
Post #84992 18th Aug 2011 9:10am
bob neville
If I change mine that is exactly what I am going to do. Britcar do them for a reasonable price.
Bob
Post #84997 18th Aug 2011 9:25am
bob neville
Part no's
NRC9448 , blue/red - drivers side
NRC9449 , yellow/white - passenger side.
Bob
Post #85001 18th Aug 2011 10:21am
MK
You can also save some cash and fit either the RBC100111 rubberized shock tower ring or the ANR2938 spring isolator, both giving 10-12 mm of lift. Thumbs Up Puma 110" SW
Post #85010 18th Aug 2011 11:32am
CFB
Genuine parts are around £38 each, aftermarket around £15
Think I'll stick to genuine stuff. Andy
Post #85028 18th Aug 2011 2:43pm
