Home > Puma (Tdci) > 2011 Defender PUMA 2.4 Error PCM |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2586 |
hmm, are you sure these Puma injectors can be repaired?
Maybe try swap injectors from another Puma? -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
25th Mar 2021 1:54pm |
it seems this is quite common on the Transit vans, and fairly easy to fix:
"Broken wire in the plug near fuse box under bonnet,the oblong one taped to main engine loom.": https://fordtransit.org/forum/viewtopic.ph...93&c=1 "Van is fixed cost £15 ignition switch , I was under impression if van cranked and all lights come on dash ignition was ok, Garage said poor contact on ignition switch caused lower voltage when cranking to pcm which shut down fueling causing fault codes and that the rac bloke was a div lol hope this helps someone cheers": https://fordtransit.org/forum/viewtopic.php?t=174106&c=1 "What I found was the engine bay loom was not clipped in where it was supposed to be and had been moving around and a some point was rubbing off the belt, where the water pump is... I just fixed the broken wires and she started straight up.. Cleared the codes and they stayed cleared.. ": https://fordtransit.org/forum/viewtopic.php?f=5&t=205094 -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
25th Mar 2021 2:14pm |
George, any feedback? --
26th Mar 2021 7:17am |
George_S Member Since: 13 Nov 2012 Location: Mondeor Posts: 4 |
Hi Naks, 2 injectors temporarily replaced with garage spares. They tested over 300km with no failures. I have since done over 500km more, including 126km towing. No problems with starting. Will probably have to replace both??
1st Apr 2021 10:17am |
Ah, so it was the injectors then.
Yeah, best to replace them with brand new ones. -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
1st Apr 2021 11:53am |
