Home > Maintenance & Modifications > Fitting gull wings to a panel van 110 |
Terryt Member Since: 28 Jun 2012 Location: Lerryn. Cornwall. Posts: 750 |
Afternoon all got a bit of a question please . We have a panel 110 and we want to fit the larger front runner gull wing window to one side as we are doing a dormobile conversion.
The panel has what I’m assuming are stiffners along the panel the window will go across one of these can these be simply drilled out without major issues. Click image to enlarge Click image to enlarge |
19th Feb 2021 5:58pm |
Yes, the frame of the gullwing will provide the necessary stiffness. Darren
19th Feb 2021 6:11pm |
Outstanding sir thank you very much .
19th Feb 2021 6:12pm |
stew 46 Member Since: 26 Jan 2012 Location: Wadebridge ,cornwall . Posts: 561 |
Nice to know there’s a forum member just down the road
19th Feb 2021 9:46pm |
Lol I’m over in Lerryn now still close .
19th Feb 2021 9:48pm |
Very nice over there , my old dad had a mooring at Golant for 25 odd years
19th Feb 2021 9:50pm |
Thank you . I figured it was just thought I’d check before I make a tit of myself
19th Feb 2021 10:54pm |
Vogler Member Since: 02 Nov 2014 Location: Brussels Posts: 309 |
Dutch Company Explore Glazing has a range of replacement windows, including gullwings and horizontally split windows for a hardtop 110.
Fitted them to mine two years ago. Click image to enlarge Click image to enlarge J Antares Treadwell, a MY06 110 Td5 in Chawton White |
20th Feb 2021 10:31am |
Thank you very much for this .I did spot these when I was search the sight and although I like the look we preferred the single large window . Nice look landy you have .
20th Feb 2021 2:27pm |
Thanks! If only one day it would look as nice inside
I think these windows are a bit smaller in height than the SW type, which limits their maximum opening angle. There were a few times when I bumped my head against them quite hard. One mod that I still have to look into is creating the possibility to open the latches from the inside. Good luck with the build! J Antares Treadwell, a MY06 110 Td5 in Chawton White |
20th Feb 2021 2:38pm |
