Home > Maintenance & Modifications > Fitting gull wings to a panel van 110
Terryt
Afternoon all got a bit of a question please . We have a panel 110 and we want to fit the larger front runner gull wing window to one side as we are doing a dormobile conversion.
The panel has what I’m assuming are stiffners along the panel the window will go across one of these can these be simply drilled out without major issues.
Post #886552 19th Feb 2021 5:58pm
Yes, the frame of the gullwing will provide the necessary stiffness. Darren
Post #886557 19th Feb 2021 6:11pm
Terryt
Outstanding sir thank you very much .
Post #886558 19th Feb 2021 6:12pm
stew 46
England 2010 Defender 110 Puma 2.4 USW Bonatti Grey
Nice to know there’s a forum member just down the road Thumbs Up Thumbs Up
Post #886623 19th Feb 2021 9:46pm
Terryt
Lol I’m over in Lerryn now still close .
Post #886624 19th Feb 2021 9:48pm
stew 46
Very nice over there Thumbs Up , my old dad had a mooring at Golant for 25 odd years Thumbs Up
Post #886625 19th Feb 2021 9:50pm
LRA is right there, they are removed on mine as it has side windows fitted.
They are just there to prevent panel flex I would have thought due to area.
Fitting what you want to fit will make up for that no problem as the structural strength is mostly above and below.
Don’t forget to measure multiple times and cut once with this job. Thumbs Up ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #886632 19th Feb 2021 10:02pm
Terryt
Thank you . I figured it was just thought I’d check before I make a tit of myself
Post #886646 19th Feb 2021 10:54pm
Vogler
Belgium 2015 Defender 110 Td5 HT Chawton White
Dutch Company Explore Glazing has a range of replacement windows, including gullwings and horizontally split windows for a hardtop 110.
Fitted them to mine two years ago.
J Antares Treadwell, a MY06 110 Td5 in Chawton White
Post #886689 20th Feb 2021 10:31am
Terryt
Thank you very much for this .I did spot these when I was search the sight and although I like the look we preferred the single large window . Nice look landy you have .
Post #886730 20th Feb 2021 2:27pm
Vogler
Thanks! If only one day it would look as nice inside Laughing
I think these windows are a bit smaller in height than the SW type, which limits their maximum opening angle. There were a few times when I bumped my head against them quite hard.
One mod that I still have to look into is creating the possibility to open the latches from the inside.
Good luck with the build!
Post #886737 20th Feb 2021 2:38pm
