![]() | Home > Maintenance & Modifications > Fitting gull wings to a panel van 110 |
Terryt Member Since: 28 Jun 2012 Location: Lerryn. Cornwall. Posts: 750 ![]() ![]() |
Afternoon all got a bit of a question please . We have a panel 110 and we want to fit the larger front runner gull wing window to one side as we are doing a dormobile conversion.
The panel has what I’m assuming are stiffners along the panel the window will go across one of these can these be simply drilled out without major issues. ![]() Click image to enlarge ![]() Click image to enlarge |
Yes, the frame of the gullwing will provide the necessary stiffness. Darren
Outstanding sir thank you very much .
stew 46 Member Since: 26 Jan 2012 Location: Wadebridge ,cornwall . Posts: 561 ![]() ![]() ![]() |
Nice to know there’s a forum member just down the road
Lol I’m over in Lerryn now still close .
Very nice over there
Thank you . I figured it was just thought I’d check before I make a tit of myself
Vogler Member Since: 02 Nov 2014 Location: Brussels Posts: 309 ![]() ![]() ![]() |
Dutch Company Explore Glazing has a range of replacement windows, including gullwings and horizontally split windows for a hardtop 110.
Fitted them to mine two years ago. ![]() Click image to enlarge ![]() Click image to enlarge J Antares Treadwell, a MY06 110 Td5 in Chawton White |
Thank you very much for this .I did spot these when I was search the sight and although I like the look we preferred the single large window . Nice look landy you have .
Thanks! If only one day it would look as nice inside
![]() I think these windows are a bit smaller in height than the SW type, which limits their maximum opening angle. There were a few times when I bumped my head against them quite hard. One mod that I still have to look into is creating the possibility to open the latches from the inside. Good luck with the build! J Antares Treadwell, a MY06 110 Td5 in Chawton White |
