Home > Faults & Fixes (L663) > Intelligent AWD only drives in 2WD
Page 6 of 19 <123 ... 567 ... 171819>
I'd be more concerned about the software engineer who programmed the AWD to go from 2wd to 4wd almost instantaneously and then wrote the logic to enable it to swap between the two states constantly just because he /she could and not having any knowledge of the lack of mechanical sympathy it was showing to the clutch packs.
Post #889475 6th Mar 2021 6:21pm
Digger2000 wrote:
Another problem that the LR assist engineer noticed yesterday was the engine coolant was nearly empty!
Was that an eyeball check or software code?
Post #889486 6th Mar 2021 7:02pm
Digger2000
United Kingdom 2006 Defender 90 Other HT Tonga Green
It was eyeball check with the LR assist engineer. I told him I noticed the engine cover had a liquid stain on it so he popped the bonnet and had a look, dipped his finger on it to taste it and initially said there was no taste so must be water, about 30 seconds later he said hold on there’s an aftertaste here and then checked the coolant which was at its minimum level which he said should not be like that on a brand new vehicle so he filled it back up and took the car for a test drive to listen for the mechanical noise. He came back and was working on the car for about 30 minutes before he knocked on the door to tell me it’s got to come off the road there is a problem with the differentials and that it was a software problem. He looked concerned to be honest gave me a look as if to say this isn’t good.
Post #889500 6th Mar 2021 7:36pm
Digger2000
I must admit when I saw they changed it from permanent 4x4 to iAWD my thoughts were why are they doing this on a defender that should be 4x4 all the time. They are only make the vehicle more complex and asking for trouble.
Post #889501 6th Mar 2021 7:41pm
Digger2000
Today when I drove the car into service department the receptionist informed me she was not expecting my vehicle in and that the Range Rover I was supposed to get was broken then she phoned someone and they were discussing vehicles they could give me she mentioned many were off the road for faults or recalls. Doesn’t fill you with confidence in the brand does it?!
Post #889504 6th Mar 2021 7:45pm
Logannz
New Zealand
Hopefully this ridiculous system can be disabled, and the car left in 4wd all the time. I'll live with a percent or two higher fuel usage.
Post #889566 7th Mar 2021 12:19am
Q86ARR
Looks like it could be a configuration error
I would point your dealer to the following document:
SSM75294 - Defender (L663) & Discovery (L462) 21MY - 2 wheel drive only displayed in IPC
Post #889585 7th Mar 2021 9:28am
Can you upload a copy?
Post #889593 7th Mar 2021 10:07am
Digger2000
Thanks, any documentation on this that you could share would be much appreciated. I’m now worried about the engine coolant tank though.
I’ve asked LR if they can replace the vehicle. Not happy with a brand new vehicle doing this the second day I drove it.
Post #889602 7th Mar 2021 10:51am
Mitcha
Ukraine
Have the same issue. So at least you are not alone anymore. No mechanical problems or noises though, just a message on the dash. Visiting a dealer today. Keep posting.
Post #889768 8th Mar 2021 9:23am
Digger2000
Check your engine coolant tank level. Apparently the problem is the differentials but the Land Rover assist engineers diagnostic test showed 4 warning codes. I’m considering instructing a solicitor to deal with this. Will keep you posted.
Post #889804 8th Mar 2021 12:02pm
Digger2000
This is becoming a joke....just had a voice message left on my phone from the dealership to confirm if I will be dropping my vehicle off with the service department for tomorrow morning!...they already have my vehicle! Mad terrible dealership I won’t be using them again.
Post #889894 8th Mar 2021 4:14pm
They won't be wanting the RRS back then... Whistle
Post #889924 8th Mar 2021 6:26pm
Digger2000
Laughing It wouldn’t surprise me if there had been a few cars go missing from this dealership.
LR resolution have just been on the phone and I gave them all the details of the problems with my car and how the dealership imo are at fault etc they have tried calling the dealership but couldn’t get through, if they can’t get through by tomorrow lunchtime an email will be sent to the service manger to get in touch ASAP. I’m due a call from LRR sometime tomorrow with an update.
Post #889929 8th Mar 2021 6:46pm
spudfan
Ireland
From December 1987 brochure for the then 90/110 models regarding the benefits of permanent 4wd.
I currently drive a Puma which I am happy with. I have nothing against the new model per se but it just is not for me. I feel for anybody who is having problems with a vehicle and from what I have read in this thread everyone seems to be on a learning curve at the expense of the owner. I hope this is sorted soon and you can get back to enjoying your pride and joy. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #890223 9th Mar 2021 5:13pm
