Home > Puma (Tdci) > Heater Matrix??
Heater Matrix??
Hello folks,
I was out in my 110 last night and when I got home and opened the door so the interior light came on, I noticed a lot of water in the passenger footwell. When investigating today in the daylight, I've found this:
I'm thinking split heater matrix. Does that sound plausible? Darren
Post #880320 23rd Jan 2021 2:44pm
Badger110
United Kingdom 2011 Defender 110 Puma 2.4 USW Buckingham Blue
Yup looks about right.
Heater matrix input/output comes in on the passenger side, however it’s a factory fitting into the matrix itself, the connections to it are in the engine bay just beyond the bulkhead.
How’s the coolant level?
Post #880323 23rd Jan 2021 3:00pm
dorsetsmith
https://parts.jaguarlandroverclassic.com/l...eater.html
Post #880326 23rd Jan 2021 3:20pm
Ouch Sad
Coolant level is ok but I'd only been for a short drive of a couple of miles when I noticed it. I took it out again today to get it warm and see if I could replicate it but couldn't. I did have the heater temperature turned to 'cold' though.
Unfortunately, I'm not going to have time to tackle this so I'll have to book it in Rolling Eyes Darren
Post #880352 23rd Jan 2021 6:26pm
Leamreject
Italy 2011 Defender 90 Puma 2.4 HT Fuji White
You would think heater matrix, but I would have expected to see the colour of the stain to reflect your coolant rather than just brown rusty water...
And if your coolant level hasn’t dropped that’s another sign it’s something else. Ride like you stole it!!
If I’m not on a bike it’s because only a 4x4 will do…
2011 2.4 Puma 90 HT
Post #880357 23rd Jan 2021 6:42pm
Pacha
I would have expected to see some evidence of coolant (and the associated smell). Rgds.
Chris
Post #880360 23rd Jan 2021 6:54pm
I would expect to see some evidence of lost coolant for a discharge of that size. Is it possible that the heater intake has filled with water since you last used the vehicle? If the drain teats are blocked and the rain has got it, it is possible that that has come through the air passages.
Dealer/garage charges for changing the heater matrix will be high due to the need to remove the complete dash, I am afraid.
Post #880365 23rd Jan 2021 7:15pm
Leamreject
Yes the smell of antifreeze would be obvious, although if you are using a waterless coolant there might not be such a smell.
With all the rain we’ve recently had my heater fan blew water droplets up the screen on full speed, so possibly a water collection somewhere perhaps. Question Ride like you stole it!!
2011 2.4 Puma 90 HT
Post #880379 23rd Jan 2021 7:44pm
Pacha
My money is on this - clogged drain valve with associated accumulation of water in heater intake. Thumbs Up Rgds.
Chris
Post #880385 23rd Jan 2021 8:01pm
dorsetsmith
A/C fitted Question
Post #880388 23rd Jan 2021 8:06pm
90dv
United Kingdom 1990 Defender 90 200 Tdi CSW Keswick Green
Judging by the drips on the left hand side, I’m guessing you’ve got a water leak into the vehicle from rain water etc and it’s been sat somewhere then when you’ve driven it dripped out. Hence the rusty colour.
Post #880407 23rd Jan 2021 9:27pm
Hmm Confused The heater intake has been protected by a snow cowl for the last three years so it won't to be that.
There's still coolant in the header tank - a quick finger dip test - but I don't know if the level has changed. If it had dropped even half an inch then that'd be quite a volume. The coolant is the same colour as what can be seen in the picture and didn't particularly smell but I'll confess that I didn't pay a lot of attention to that this morning. I'll have to check again tomorrow.
Yes, it has aircon.
The idea that there's a reservoir of rusty water sitting in the bulkhead somewhere is rather worrying. The vehicle hasn't been sitting around unused for any length of time though so it seems unlikely.
It sounds like taking the dash out may be the only way to be sure Rolling Eyes Darren
Post #880423 23rd Jan 2021 11:45pm
LRA wrote:
...Yes, it has aircon....
Sadly that will make changing a heater matrix even more expensive due to the second heat exchanger built into your heater box and the need to empty and refill the a/c system.
Post #880429 24th Jan 2021 12:18am
Deep joy. Darren
Post #880435 24th Jan 2021 12:41am
Dinnu
If it was coolant, would it just drib on the transmission tunnel? Very clear marks on the transmission tunnel. But then how did the water get on the side of the bulkhead (I mean where the bottom door hinge would be).
There is kind of an inspection hatch in the dash (similar to the fuse box under the steering wheel) perhaps you can peep in there to get another clue. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #880470 24th Jan 2021 10:09am
