![]() | Home > Puma (Tdci) > Heater Matrix?? |
Hello folks,
I was out in my 110 last night and when I got home and opened the door so the interior light came on, I noticed a lot of water in the passenger footwell. When investigating today in the daylight, I've found this: ![]() Click image to enlarge I'm thinking split heater matrix. Does that sound plausible? Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
![]() Click image to enlarge https://parts.jaguarlandroverclassic.com/l...eater.html Last edited by dorsetsmith on 23rd Jan 2021 6:44pm. Edited 1 time in total |
Ouch
![]() Coolant level is ok but I'd only been for a short drive of a couple of miles when I noticed it. I took it out again today to get it warm and see if I could replicate it but couldn't. I did have the heater temperature turned to 'cold' though. Unfortunately, I'm not going to have time to tackle this so I'll have to book it in ![]() 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Leamreject Member Since: 19 Dec 2020 Location: Middle Earth - Leamington Spa Posts: 970 ![]() ![]() ![]() |
You would think heater matrix, but I would have expected to see the colour of the stain to reflect your coolant rather than just brown rusty water...
And if your coolant level hasn’t dropped that’s another sign it’s something else. Ride like you stole it!! If I’m not on a bike it’s because only a 4x4 will do… 2011 2.4 Puma 90 HT |
Pacha Member Since: 23 Feb 2020 Location: North Yorkshire Posts: 781 ![]() ![]() ![]() |
I would have expected to see some evidence of coolant (and the associated smell). Rgds. Chris |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18028 ![]() ![]() ![]() |
I would expect to see some evidence of lost coolant for a discharge of that size. Is it possible that the heater intake has filled with water since you last used the vehicle? If the drain teats are blocked and the rain has got it, it is possible that that has come through the air passages.
Dealer/garage charges for changing the heater matrix will be high due to the need to remove the complete dash, I am afraid. |
Yes the smell of antifreeze would be obvious, although if you are using a waterless coolant there might not be such a smell. With all the rain we’ve recently had my heater fan blew water droplets up the screen on full speed, so possibly a water collection somewhere perhaps. ![]() If I’m not on a bike it’s because only a 4x4 will do… 2011 2.4 Puma 90 HT |
My money is on this - clogged drain valve with associated accumulation of water in heater intake. ![]() Chris |
A/C fitted
90dv Member Since: 29 Jun 2011 Location: Cumbria Posts: 39 ![]() ![]() ![]() |
Judging by the drips on the left hand side, I’m guessing you’ve got a water leak into the vehicle from rain water etc and it’s been sat somewhere then when you’ve driven it dripped out. Hence the rusty colour.
Hmm
![]() There's still coolant in the header tank - a quick finger dip test - but I don't know if the level has changed. If it had dropped even half an inch then that'd be quite a volume. The coolant is the same colour as what can be seen in the picture and didn't particularly smell but I'll confess that I didn't pay a lot of attention to that this morning. I'll have to check again tomorrow. Yes, it has aircon. The idea that there's a reservoir of rusty water sitting in the bulkhead somewhere is rather worrying. The vehicle hasn't been sitting around unused for any length of time though so it seems unlikely. It sounds like taking the dash out may be the only way to be sure ![]() 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Sadly that will make changing a heater matrix even more expensive due to the second heat exchanger built into your heater box and the need to empty and refill the a/c system. |
Deep joy. Darren
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3643 ![]() ![]() ![]() |
If it was coolant, would it just drib on the transmission tunnel? Very clear marks on the transmission tunnel. But then how did the water get on the side of the bulkhead (I mean where the bottom door hinge would be).
There is kind of an inspection hatch in the dash (similar to the fuse box under the steering wheel) perhaps you can peep in there to get another clue. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
