Home > Puma (Tdci) > P193514 Brake Switch/Sensor Signal fault- Help please!
m3vert
Scotland 2011 Defender 110 2.5 TD PU Stornoway Grey
I have had a few of the P193514 fault codes show up which my local garage thought were a sensor signal fault. They have replaced the 2 switches they thought were the likely cause but alas the fault code keeps re-appearing!
They are at a bit of a loss as to what is the issue and as they closed tonight for New Year break they gave me the landy back. They are going to make some enquiries with people they know who know Defenders better than themselves but I thought I would ask on here if anyone has any idea what could be causing this issue?
Only history I have where I had issues is the handbrake cable got fried when my battery moved as securing mechanism worked loose and battery terminal shorted out. However this was 18 months ago, maybe more. So i doubt that is related?
Any help much appreciated Smile Thanks
Post #875306 30th Dec 2020 8:55pm
dorsetsmith
abs ? as hand brake and fluid level switch is link to it Exclamation
have you checked that ecm seeing state from the brake switch i think one switch is norm close for ecm and brake light norm open
if you have open cct wiring for ecm it will not see state change from the switch
Post #875321 30th Dec 2020 9:34pm
llessur
As I have just developed a similar issue, I wondered if this was resolved and the cause identified. I have working brake lights, hand brake light and fluid level indicator, but the P193514 code comes straight back up after it has been cleared.
Post #878307 13th Jan 2021 9:00pm
