![]() | Home > Puma (Tdci) > P193514 Brake Switch/Sensor Signal fault- Help please! |
abs ? as hand brake and fluid level switch is link to it
![]() have you checked that ecm seeing state from the brake switch i think one switch is norm close for ecm and brake light norm open if you have open cct wiring for ecm it will not see state change from the switch |
llessur Member Since: 15 Nov 2011 Location: Hereford Posts: 151 ![]() ![]() |
As I have just developed a similar issue, I wondered if this was resolved and the cause identified. I have working brake lights, hand brake light and fluid level indicator, but the P193514 code comes straight back up after it has been cleared.
Matt_H Member Since: 19 Sep 2018 Location: Cornwall Posts: 45 ![]() ![]() ![]() |
Hello there all,
Did this challenge ever get solved? I have the same issue - the three dash lights, the same error code, and I've replaced both pedal switches. I clear the error off and the three lights (and same error code) just come straight back again immediately when I start the engine. Has anyone got to the bottom of this? Many thanks, Matt |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20967 ![]() ![]() |
Make sure brake fluid level is at Max. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2284 ![]() ![]() ![]() |
Brake fluid level should only be at MAX when all components are new…..as everything wears the level will naturally fall and if left too long the Fluid / Handbrake warning light illuminates to warn you…..
All fine, level at max, contacts are clean, no change and fault still returns. |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2497 ![]() ![]() ![]() |
According to the manual: Brake Sensor/Switch Signal - Short to Ground or Open Circuit Puma 110" SW
Many thanks for this.
I'm assuming this is the blue and white switch, not the black one (why there are two, but just one descriptor in the error code I do wonder!). Any insight as to where that wiring run and earth might be? Thanks again |
You can have a look into the landrover workshop web page. You will find almost all electrical diagrams. Puma 110" SW
