Home > Puma (Tdci) > P193514 Brake Switch/Sensor Signal fault- Help please!
m3vert
Scotland 2011 Defender 110 2.5 TD PU Stornoway Grey
I have had a few of the P193514 fault codes show up which my local garage thought were a sensor signal fault. They have replaced the 2 switches they thought were the likely cause but alas the fault code keeps re-appearing!
They are at a bit of a loss as to what is the issue and as they closed tonight for New Year break they gave me the landy back. They are going to make some enquiries with people they know who know Defenders better than themselves but I thought I would ask on here if anyone has any idea what could be causing this issue?
Only history I have where I had issues is the handbrake cable got fried when my battery moved as securing mechanism worked loose and battery terminal shorted out. However this was 18 months ago, maybe more. So i doubt that is related?
Any help much appreciated Smile Thanks
Post #875306 30th Dec 2020 8:55pm
dorsetsmith
abs ? as hand brake and fluid level switch is link to it Exclamation
have you checked that ecm seeing state from the brake switch i think one switch is norm close for ecm and brake light norm open
if you have open cct wiring for ecm it will not see state change from the switch
Post #875321 30th Dec 2020 9:34pm
llessur
As I have just developed a similar issue, I wondered if this was resolved and the cause identified. I have working brake lights, hand brake light and fluid level indicator, but the P193514 code comes straight back up after it has been cleared.
Post #878307 13th Jan 2021 9:00pm
Matt_H
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Zambezi Silver
Hello there all,
Did this challenge ever get solved?
I have the same issue - the three dash lights, the same error code, and I've replaced both pedal switches. I clear the error off and the three lights (and same error code) just come straight back again immediately when I start the engine.
Has anyone got to the bottom of this?
Many thanks,
Matt
Post #1074880 6th Sep 2025 5:13pm
Make sure brake fluid level is at Max. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1074881 6th Sep 2025 5:17pm
90 Dreamer
Brake fluid level should only be at MAX when all components are new…..as everything wears the level will naturally fall and if left too long the Fluid / Handbrake warning light illuminates to warn you…..
Post #1074883 6th Sep 2025 5:24pm
Matt_H
All fine, level at max, contacts are clean, no change and fault still returns.
Post #1075064 8th Sep 2025 9:50pm
MK
According to the manual: Brake Sensor/Switch Signal - Short to Ground or Open Circuit Puma 110" SW
Post #1075106 9th Sep 2025 1:19pm
Matt_H
Many thanks for this.
I'm assuming this is the blue and white switch, not the black one (why there are two, but just one descriptor in the error code I do wonder!). Any insight as to where that wiring run and earth might be?
Thanks again
Post #1075140 9th Sep 2025 7:53pm
MK
You can have a look into the landrover workshop web page. You will find almost all electrical diagrams. Puma 110" SW
Post #1075154 9th Sep 2025 9:30pm
