![]() | Home > In Car Electronics > Death throws of an alternator |
It would die now wouldn't it
![]() Basically shes not charging. If I turn everything off I get 13.4v on the radio and the dash volt meter is showing a very slight charge but the second I start turning essentials on like lights, wipers it drops down sometimes to 10v and deep into the discharge. Its not the battery as Halfords have supplied a new one FOC due to the old one having half its cranking amps within its warranty period. Looking at it, I'm going to give it its dues because its the original fitted in 1991 and I hate to think how many million revolutions it has done. ![]() Click image to enlarge I do have an uprated one new in box which would boost it to 100A but I have turned away from using it as I just don't see the need for the extra amps given what I use and want to keep it standard. All good, but everywhere that has one for a reasonable price is closed and wont be re-opening until the new year. What a pain. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter ![]() |
maybe time for an over hall https://forums.lr4x4.com/topic/22735-recon...lternator/
https://www.ebay.co.uk/itm/181327087431 the sort kit looking for also good place to look https://hc-cargo.co.uk/catalog/oem/slr4922...ood%20Auto may be brush problem ![]() Chainsaw play up late November not starting carb over hall kit and its like new ![]() |
Hi Dorset, sorry I missed this response
![]() I have ordered a new one but will have a go at rebuilding the old one so I have it on the shelf ready. Never to late to learn ![]() Self confessed mileage hunter ![]() |
ever day and ever way
Well this is frustrating.
I ordered a new alternator a while ago and it finally arrived yesterday. ![]() Click image to enlarge Its the wrong one ![]() I ordered STC229 which is the standard 200tdi 45A Alternator and received STC233G which is the optional uprated 65A one for vehicles fitted with air con or special vehicles conversions. Now after reading up a bit, I understand that the wiring loom is the same, the difference is the plug. ![]() Click image to enlarge ![]() Click image to enlarge So, do I change the plug and run it as is, or do I return it and ask them to send me the correct one? Any electrical Gurus who can shed some light Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter ![]() |
![]() Click image to enlarge two larger wires B+ and small wire two D+ |
Many thanks guys.
![]() I hate electrics and electrical work. Will gather tools and consumables get onto it. What makes this all so frustrating is all the bits I need are at my parents so I have to now go buy new ones rather than risk infecting them and all because they sent the wrong blooming one! Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter ![]() |
before you du that have look at old and see if it has B+ bolt too
I have bought these but now having got home it says only good up to 35a.
![]() Click image to enlarge Is this going to be an issue? Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter ![]() |
htb2 Member Since: 02 Nov 2018 Location: Carmarthenshire Posts: 548 ![]() ![]() |
One on each large wire and you have got 70A
Yellow pre insulated ring terminal For cables 3.0mm to 6.0mm
6.00mm cable is rated at 41 amps use one on each for the large brown cables ![]() |
Well it was all going well until I got the old one off
![]() ![]() Click image to enlarge I did look at rotating the casting but the tapped hole would be in the wrong place. Return to sender tomorrow then ![]() Self confessed mileage hunter ![]() |
repair old one at lest you no if fits
Wish I had done now would have been by far the quickest route.
Just need to get it moving again ![]() Self confessed mileage hunter ![]() |
