Home > In Car Electronics > Death throws of an alternator
shaggydog
It would die now wouldn't it Rolling Eyes
Basically shes not charging.
If I turn everything off I get 13.4v on the radio and the dash volt meter is showing a very slight charge but the second I start turning essentials on like lights, wipers it drops down sometimes to 10v and deep into the discharge. Its not the battery as Halfords have supplied a new one FOC due to the old one having half its cranking amps within its warranty period.
Looking at it, I'm going to give it its dues because its the original fitted in 1991 and I hate to think how many million revolutions it has done.
I do have an uprated one new in box which would boost it to 100A but I have turned away from using it as I just don't see the need for the extra amps given what I use and want to keep it standard.
All good, but everywhere that has one for a reasonable price is closed and wont be re-opening until the new year. What a pain. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter Very Happy
Post #874728 26th Dec 2020 5:47pm
dorsetsmith
maybe time for an over hall https://forums.lr4x4.com/topic/22735-recon...lternator/
https://www.ebay.co.uk/itm/181327087431 the sort kit looking for
also good place to look
https://hc-cargo.co.uk/catalog/oem/slr4922...ood%20Auto
may be brush problem Exclamation
Chainsaw play up late November not starting carb over hall kit and its like new Thumbs Up
Post #874737 26th Dec 2020 6:47pm
shaggydog
Hi Dorset, sorry I missed this response Embarassed
I have ordered a new one but will have a go at rebuilding the old one so I have it on the shelf ready.
Never to late to learn Thumbs Up Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #876401 5th Jan 2021 2:51pm
dorsetsmith
ever day and ever way Thumbs Up
Post #876433 5th Jan 2021 5:00pm
shaggydog
Well this is frustrating.
I ordered a new alternator a while ago and it finally arrived yesterday.
Its the wrong one Big Cry
I ordered STC229 which is the standard 200tdi 45A Alternator and received STC233G which is the optional uprated 65A one for vehicles fitted with air con or special vehicles conversions.
Now after reading up a bit, I understand that the wiring loom is the same, the difference is the plug.
So, do I change the plug and run it as is, or do I return it and ask them to send me the correct one?
Any electrical Gurus who can shed some light Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #876780 6th Jan 2021 10:04pm
htb2
Crimp 2 larger brown wires together onto a ring terminal and they go onto the 6mm output stud. The thinner brown wire with tracer goes onto the 4mm stud on the black plastic bit with another smaller ring crimp. Nothing attaches to the terminal marked W as thats for tachometer .
Post #876782 6th Jan 2021 10:10pm
dorsetsmith
two larger wires B+ and small wire two D+
Post #876788 6th Jan 2021 11:12pm
shaggydog
Many thanks guys. Bow down
I hate electrics and electrical work.
Will gather tools and consumables get onto it.
What makes this all so frustrating is all the bits I need are at my parents so I have to now go buy new ones rather than risk infecting them and all because they sent the wrong blooming one! Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #876825 7th Jan 2021 10:54am
dorsetsmith
before you du that have look at old and see if it has B+ bolt too
Post #876832 7th Jan 2021 11:09am
shaggydog
I have bought these but now having got home it says only good up to 35a.
Is this going to be an issue? Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #876937 7th Jan 2021 8:47pm
htb2
One on each large wire and you have got 70A
Post #876941 7th Jan 2021 8:53pm
dorsetsmith
Yellow pre insulated ring terminal For cables 3.0mm to 6.0mm
6.00mm cable is rated at 41 amps
use one on each for the large brown cables Thumbs Up
Post #876955 7th Jan 2021 10:35pm
shaggydog
Well it was all going well until I got the old one off Big Cry
I did look at rotating the casting but the tapped hole would be in the wrong place.
Return to sender tomorrow then Banging Head Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #877513 10th Jan 2021 3:49pm
dorsetsmith
repair old one at lest you no if fits
Post #877657 11th Jan 2021 8:51am
shaggydog
Wish I had done now would have been by far the quickest route.
Just need to get it moving again Big Cry Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #877747 11th Jan 2021 4:14pm
Site Copyright © 2006-2021 Futuranet Ltd & Martin Lewis
