Home > Maintenance & Modifications > Retro fitting Headlight level
Page 2 of 2 <12
Intercept
United Kingdom 2002 Defender 110 Td5 Black LE Java Black
boode wrote:
You can also see the new Mud USB - the green light is a bit brighter than the rest
Interesting. I've got 2 of those awaiting installation...
Post #876611 6th Jan 2021 1:20pm
SteveK
United Kingdom 2002 Defender 110 Td5 HT Rimini Red
Thread revival alert!
I am finally getting around to fitting these! I got stuck on the headlight bowls and motors. I thought that the hole at the top of the aperture was for the motor arm. However in this position none of the mounting holes align!
Turning it around 180° seems to have solved the problem! The wiring is present behind both headlights, but the connector is corroded on the O/S and I will have to replace it.
Post #978670 18th Jan 2023 4:00pm
grafty99
Unfortunately if you fit them upside down they'll work in reverse, raising the headlights rather than lowering them, I'm sure incoming traffic won't appreciate that Laughing
The motor lives and the bottom and pulls the bottom of the headlights in to dip them rather than pushing the top out Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #978776 19th Jan 2023 9:10am
SteveK
Might be good for aircraft spotting though!
That hole at 12O’Clock in the aperture really got me confused!!
Post #978795 19th Jan 2023 10:51am
grafty99
Per perhaps squirrel hunting Rolling with laughter 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #978800 19th Jan 2023 11:28am
Page 2 of 2 <12
