![]() | Home > Maintenance & Modifications > Retro fitting Headlight level |
SteveK Member Since: 21 Jan 2015 Location: Bromsgrove Posts: 335 ![]() ![]() ![]() |
Thread revival alert!
I am finally getting around to fitting these! I got stuck on the headlight bowls and motors. I thought that the hole at the top of the aperture was for the motor arm. However in this position none of the mounting holes align! Turning it around 180° seems to have solved the problem! The wiring is present behind both headlights, but the connector is corroded on the O/S and I will have to replace it. ![]() Click image to enlarge ![]() Click image to enlarge |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4802 ![]() ![]() ![]() |
Unfortunately if you fit them upside down they'll work in reverse, raising the headlights rather than lowering them, I'm sure incoming traffic won't appreciate that
![]() The motor lives and the bottom and pulls the bottom of the headlights in to dip them rather than pushing the top out ![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Might be good for aircraft spotting though!
That hole at 12O’Clock in the aperture really got me confused!! |
Per perhaps squirrel hunting
