Home > General & Technical (L663) > Owners Manual and Service Costs
Page 2 of 2 <12
Digger2000
United Kingdom 2006 Defender 90 Other HT Tonga Green
lohr500 wrote:
Sorry just read your reply about it being a diesel.
Same check but on a D240 gives this. I can't see the service interval being different for the new MHEV 3 litre diesel.
24 months before they change the oil seems a long time for me. Think I’d get mine done after 12 months.
Post #868559 20th Nov 2020 12:59pm
Tim in Scotland
Oil life will depend on how you use the car I suppose and plenty of other manufacturers go 2 years between oil changes even in their rep-mobiles that often lead a very hard life. My own car is unlikely to exceed 16,000 miles in 2 years, might not even do 12000 miles if we keep getting lock downs. I’m sure if the car wants an oil change before 24 months it will tell you through the monitoring system that has highlighted the oil dilution issues in other cars. I’m like you though, no harm done in doing more frequent filter and oil changes, although I suspect with all that cladding under the car it might not be so easy to do as a DIY job as you might need an assistant to get those panels off to get at the drain plug Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed!
Post #868560 20th Nov 2020 1:13pm
DSL
In this day and age don’t they just suck the oil out of a tube? Don’t suppose they have dipsticks? Whistle
Post #868561 20th Nov 2020 1:15pm
Tim in Scotland
My D240 has a dipstick - horrid long thing it is too, really difficult to get it back down the tube after you remove it to check the level.
Post #868562 20th Nov 2020 1:27pm
J77
My velar got its first service at 2 years old, no issues whatsoever. A lot of owners will exceed the mileage before the 2 years are up anyway.
Hopefully my Defender will as reliable (mechanically) as my Velars D240, I’m not a high mileage user, my LRs are my weekend toys if you like, my Velar will be 3 in January and will have just broke 15000 miles (would’ve been nearer 20000 if not for the pandemic). Sod’s law February will be when issues arise as it will be out of warranty for a month before the Defender arrives.
Post #868563 20th Nov 2020 1:29pm
Digger2000
Doesn’t look that hard of a job tbh but I’ll probably just take mine to local garage to change it after first year.
Post #868571 20th Nov 2020 2:13pm
discomog
I cannot believe it took him 40 minutes to change the oil and oil filter. Whistle Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #868576 20th Nov 2020 2:57pm
Simon Audi
So following on from Earlier Suggestion
I used a reg of a near new RRSport - with same D300 Engine
Your Vehicle
LAND ROVER R, 3 Diesel, Automatic, 0 miles, 28/09/2020, YC70AVF
Your Service Plan
Your service schedule detailed below has been estimated based on the age of your car and the current mileage you have entered.
Your Plan - Range Rover Sport_3L_D_Auto_4WD_MHEV_Without Dynamic Response
Service 1: 21,000 miles / 24 months
Service Due: September 2022
Brake Fluid
Engine Oil
Labour Hours - (1.3)
Oil Filter
Pollen Filter
Washer Fluid
Service 2: 42,000 miles / 48 months
Service Due: September 2024
Air Filter(s)
Brake Fluid
Engine Oil
Fuel Filter
Labour Hours - (1.6)
Oil Filter
Pollen Filter
Washer Fluid
Service 3: 63,000 miles / 72 months
Service Due: September 2026
Belt Intergrated Starter Generator Belt
Brake Fluid
Brake Hoses
Engine Oil
Labour Hours - (2.1)
Oil Filter
Pollen Filter
Rear Locking Diff Oil - Additional Labour Hours (0.2)
Stabilizer Bar Link Nut
Transfer Box Drain/Fill Plug Washer
Transfer Box Oil
Washer Fluid
Water Pump Drive Belt
Rear Locking Diff Drain Plug
Rear Locking Diff Fill Plug
Your Payment Plan
Payment options
Fixed payments
1 monthly payment of:
£37.63
65 monthly payments of:
£37.00
First payment due:
04/12/2020
Plan total price:
£2,442.63
Continue
Post #868620 20th Nov 2020 5:42pm
AT1963
United Kingdom 2006 Defender 90 Td5 Black LE Java Black
I have an evoque which has a 2 year service interval but it is changed every year.
Is it really that good to have oil hat is 2 yrs old in your vehicle??
Post #869057 22nd Nov 2020 10:25pm
Page 2 of 2 <12
