![]() | Home > General & Technical (L663) > Owners Manual and Service Costs |
| Tim in Scotland Member Since: 23 May 2007 Location: The Land that time forgot Posts: 3753
Oil life will depend on how you use the car I suppose and plenty of other manufacturers go 2 years between oil changes even in their rep-mobiles that often lead a very hard life. My own car is unlikely to exceed 16,000 miles in 2 years, might not even do 12000 miles if we keep getting lock downs. I’m sure if the car wants an oil change before 24 months it will tell you through the monitoring system that has highlighted the oil dilution issues in other cars. I’m like you though, no harm done in doing more frequent filter and oil changes, although I suspect with all that cladding under the car it might not be so easy to do as a DIY job as you might need an assistant to get those panels off to get at the drain plug Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
| DSL Member Since: 20 Aug 2007 Location: Wandering the wasteland. Posts: 837
In this day and age don’t they just suck the oil out of a tube? Don’t suppose they have dipsticks?
My D240 has a dipstick - horrid long thing it is too, really difficult to get it back down the tube after you remove it to check the level.
2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! Last edited by Tim in Scotland on 20th Nov 2020 12:30pm. Edited 1 time in total |
| J77 Member Since: 04 Nov 2019 Location: Fife Posts: 3526
My velar got its first service at 2 years old, no issues whatsoever. A lot of owners will exceed the mileage before the 2 years are up anyway.
Hopefully my Defender will as reliable (mechanically) as my Velars D240, I’m not a high mileage user, my LRs are my weekend toys if you like, my Velar will be 3 in January and will have just broke 15000 miles (would’ve been nearer 20000 if not for the pandemic). Sod’s law February will be when issues arise as it will be out of warranty for a month before the Defender arrives. |
| Digger2000 Member Since: 19 Sep 2020 Location: Newcastle Posts: 590
Doesn’t look that hard of a job tbh but I’ll probably just take mine to local garage to change it after first year. |
| discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2544
I cannot believe it took him 40 minutes to change the oil and oil filter.
| Simon Audi Member Since: 19 Nov 2020 Location: Newport Posts: 544
So following on from Earlier Suggestion
I used a reg of a near new RRSport - with same D300 Engine Your Vehicle LAND ROVER R, 3 Diesel, Automatic, 0 miles, 28/09/2020, YC70AVF Your Service Plan Your service schedule detailed below has been estimated based on the age of your car and the current mileage you have entered. Your Plan - Range Rover Sport_3L_D_Auto_4WD_MHEV_Without Dynamic Response Service 1: 21,000 miles / 24 months Service Due: September 2022 Brake Fluid Engine Oil Labour Hours - (1.3) Oil Filter Pollen Filter Washer Fluid Service 2: 42,000 miles / 48 months Service Due: September 2024 Air Filter(s) Brake Fluid Engine Oil Fuel Filter Labour Hours - (1.6) Oil Filter Pollen Filter Washer Fluid Service 3: 63,000 miles / 72 months Service Due: September 2026 Belt Intergrated Starter Generator Belt Brake Fluid Brake Hoses Engine Oil Labour Hours - (2.1) Oil Filter Pollen Filter Rear Locking Diff Oil - Additional Labour Hours (0.2) Stabilizer Bar Link Nut Transfer Box Drain/Fill Plug Washer Transfer Box Oil Washer Fluid Water Pump Drive Belt Rear Locking Diff Drain Plug Rear Locking Diff Fill Plug Your Payment Plan Payment options Fixed payments 1 monthly payment of: £37.63 65 monthly payments of: £37.00 First payment due: 04/12/2020 Plan total price: £2,442.63 Continue |
| AT1963 Member Since: 08 Jul 2020 Location: Leicestershire Posts: 148
I have an evoque which has a 2 year service interval but it is changed every year.
Is it really that good to have oil hat is 2 yrs old in your vehicle?? |
| All times are GMT |
