Home > Puma (Tdci) > BULKHEAD bar |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3204 |
The bulkhead delete bar consists of 3 main parts. 2 vertical tubes from the cappings to the front panel of the wheel arch, and a horn shape tube that goes across the vehicle.
You can easily remove the horn shape tube. I believe the 2 pairs of bolts that go through the floor go in a plate with 2 nuts welded on. To remove is not a big deal, but to re install you need to sort of align the plate from the bottom, and they are hidden by the seatbelt brackets. To remove the 2 vertical tubes, you need to remove the side panels to gain access to the bolts that go through the cappings. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
9th Oct 2020 6:28pm |
SVX90 Member Since: 31 Aug 2009 Location: Dubai Posts: 38 |
Thank you so much for your reply. tomorrow I will sent you pictures explaining why I am having trouble with.
9th Oct 2020 9:20pm |
bolted and welded at the same time
10th Oct 2020 10:31am |
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge .... |
10th Oct 2020 10:36am |
That’s just bolted. Take the four bolts in the pictures out then there are four on the floor too. Only the long cross bar will come out because the uprights are pop riveted to the cappings so the body sides would need removing to take those off Ray
10th Oct 2020 10:59am |
[quote="SVX90"]
Click image to enlarge The welds are only on one side of the saddle clamp. Once you take out those 2 bolts, it will come apart. Of course have to do the other side. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
10th Oct 2020 3:46pm |
JOB DONE>
Click image to enlarge |
20th Nov 2020 9:07am |
