Home > Puma (Tdci) > BULKHEAD bar
SVX90
United Arab Emirates
BULKHEAD bar
Hello everyone.
2008 defender 90 here
My question is regarding the bulkhead bar that is already installed in my vehicle. Can it be removed. Or is it factory welded?
I am installing Dinamats and some waterproof interior foam like material and it would be much much easier if the bar wasn't there during installation.
Thanks
Post #860639 9th Oct 2020 1:42pm
Dinnu
The bulkhead delete bar consists of 3 main parts. 2 vertical tubes from the cappings to the front panel of the wheel arch, and a horn shape tube that goes across the vehicle.
You can easily remove the horn shape tube. I believe the 2 pairs of bolts that go through the floor go in a plate with 2 nuts welded on. To remove is not a big deal, but to re install you need to sort of align the plate from the bottom, and they are hidden by the seatbelt brackets.
To remove the 2 vertical tubes, you need to remove the side panels to gain access to the bolts that go through the cappings. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #860689 9th Oct 2020 6:28pm
SVX90
Thank you so much for your reply. tomorrow I will sent you pictures explaining why I am having trouble with.
Post #860732 9th Oct 2020 9:20pm
SVX90
bolted and welded at the same time Big Cry
Post #860802 10th Oct 2020 10:31am
SVX90
Post #860803 10th Oct 2020 10:36am
mk1collector
That’s just bolted. Take the four bolts in the pictures out then there are four on the floor too. Only the long cross bar will come out because the uprights are pop riveted to the cappings so the body sides would need removing to take those off Ray
My build thread
Post #860809 10th Oct 2020 10:59am
Dinnu
[quote="SVX90"]
The welds are only on one side of the saddle clamp. Once you take out those 2 bolts, it will come apart. Of course have to do the other side. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #860843 10th Oct 2020 3:46pm
SVX90
JOB DONE>
Post #868501 20th Nov 2020 9:07am
