![]() | Home > Puma (Tdci) > Turbo actuator plug |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3605 ![]() ![]() ![]() |
This thread might help: https://www.defender2.net/forum/topic73806...verheating
I would investigate why the temperature is climbing to 110dC first and foremost. since temperature drops to 90dc when there is less load, then it points to poor heat dissipation.. check radiator for clogging with leaves, dirt etc. Good to check the viscous coupling on the radiator fan making sure that it draws enough air. Coolant level is correct. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8396 ![]() ![]() ![]() |
Is it getting hot due to excess fuel incease in egt from turbo issues still. What boost is being made at fault occurrence point? Cheers
Primaryroo Member Since: 15 Aug 2020 Location: kent Posts: 21 ![]() ![]() ![]() |
well got bored and investigated.
took rad out cleaned through outside and in, loads of mud in veins changed fluid to high quality coolant changed water pump changed thermostat (original 2007) found after searching online and found exact same thermostat for MG temp 78 degree (havent fitted ,,,,a just in case thingy temp is now 10 degree lower and towed caravan, temp didnt go above 92 even going up steep long hill temp gauge is physically lower on needle fingers crossed ( also now have plugged egr back in so thats back in the loop ) it still cools down instanltly when load finnished (but am i being overly concerned due to nanocom instantly updating temp ) series 2a 1966 defender 90 1991 discovery 3 2005 discovery 2 2003 defender puma 110 2008 defender puma ex scottish power 2.4 2011 |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2358 ![]() ![]() ![]() |
Hope you've got it sorted. If it reoccurs have a look at my post here about "P0234-00 (28 ) turbo overboost condition" error and the steps I took to sort it
https://www.defender2.net/forum/topic53240-113.html > 110 XS Double Cab |
