Home > My Defender > hanks Double Cab
Page 8 of 22 <123 ... 789 ... 202122>
hank
Recently I've been experiencing the occasional "P0234-00 (28 ) turbo overboost condition" error which puts the vehicle into what feels like normally aspirated / limp mode until the fault is cleared.
Research suggested this could be a sign that the variable geometry turbo vanes were gunked up and sticky and I figured this was likely due to manky crankcase fumes being recirculated into the turbo inlet.
As a test I disconnected the crankcase pressure recirculation hose from the turbo inlet, venting it to atmosphere. I also sprayed a can of wynns turbo cleaner through the turbo for good measure.
Sure enough 2000 miles later no further overboost errors. However, the crankcase fumes were pretty bad so I needed a permanent solution. (It would also be an MOT fail)
On investigation, the rocker cover pressure relief valve diaphragm had gone hard and crusty so I replaced that with a nice new flexible one Mr. Green
While I was there I also fitted a Provent 100 - I went for the 100 because it's compact which is advantageous given the limited space in the engine bay but also because the inlet and outlet are 19mm which is useful as they match the existing Defender breather fittings so no adapter fittings required.
Today I fabricated a bracket to mount the Provent which picks up on the clutch pedal box cover screws and plumbed it courtesy of a Corsa 1.3 CDTI breather hose from rocker cover outlet to Provent and the original, trimmed, Defender hose from Provent back to turbo inlet.
Pleased with how it turned out, looks kind of OEM and the fumes exhausted from the Provent are spotless whereas previously they were grey smokey/oily and rank.
Anyway, a few photos...
Cardboard template for the Provent bracket. Unfortunately I forgot to take a photo of the steel bracket which has welded nuts for mounting the Provent
Provent fitted and plumbed.
 > 110 XS Double Cab
Post #851987 25th Aug 2020 8:05pm
Zed
United Kingdom 2010 Defender 110 Puma 2.4 XS CSW Santorini Black
Nicely done. You'll be surprised how much oil it catches. WARNING.
This post may contain sarcasm.
Post #851991 25th Aug 2020 8:17pm
hank
Yeah? I've put a length of opaque pipe on the waste as a temporary measure but will fit a transparent hose and tap arrangement when I get one so I can monitor the waste oil level > 110 XS Double Cab
Post #852112 26th Aug 2020 11:20am
hank
Rocker cover subcover fitted Rolling Eyes
Why does this part have sealing o-ring but holes open to atmosphere below Laughing
 > 110 XS Double Cab
Post #854233 4th Sep 2020 1:30pm
Zed
2 questions.
What is that for?
and
Where do you put your beer/tea/fixings? WARNING.
Post #854244 4th Sep 2020 2:32pm
hank
And the final piece of the provent puzzle... Waste drain and tap plumbed to behind the front offside radius arm mounting, retained by a hose clip in an existing hole
 > 110 XS Double Cab
Post #854245 4th Sep 2020 2:38pm
hank
Zed wrote:
2 questions.
What is that for?
and
Its primary purposes it to avoid comments like those below Razz Beer goes in my mouth and fixings typically into the drain
Mo Murphy wrote:
You have a cup holder in your engine bay, that's useful ! Wink
 > 110 XS Double Cab
Post #854247 4th Sep 2020 2:40pm
hank
Having run the Provent for a few weeks I was not happy with the quantity of oil the engine was putting out via the breather due to excess crankcase pressure so decided to revisit the injector seal washers (AGAIN Big Cry ). I could hear injectors ticking, especially when I opened the oil filler so at least one injector was not sealing.
The only thing I had missed previously (because I didn't have the tool) was cleaning up the injector seats so I got myself a seat cutter (15mm flat for those wondering) and set to it.
The injectors were heavily carbon'd up so there had clearly been blow by and inspecting each injector hole with a borescope I could see a fair bit of carbon buildup around the injector seat where the copper washer seals.
I cleaned up the four seats with the cutter being careful to remove only the carbon and no aluminium head material. I also cleaned up the bores to avoids any bits getting knocked down onto the seat. Inspecting with the borescope you can see the seats ended up back to bare metal.
Also cleaned out the rocker cover breather system whilst it was apart. Cleared all the gunk and carbon out of the internal breather passage and the diaphragm etc. Surprising how caked this was! Obviously cleaned the injectors right up too.
Reassembled with new OE copper washers, new clamp bolts to 6Nm+180, new return seal o-rings and a new rocker cover gasket. The crankcase pressure seems to have reduced so will keep an eye on how much oil the Provent catches over time. The injector ticking noise has stopped so definite improvement and the vehicle feels as though it's driving better... But this could be psychological Whistle
I will remove the injector cover after a few heat/cool cycles to check that the injector clamp bolts are still tight as I wonder whether heating/expansion and cooling/contraction of the components may leave these out of spec causing the washers not to seal. Don't know.
Fingers crossed this time gets it! Some photos...
State of the injectors
Injector seats (photos taken by my glamorous assistant)
Injector seats after cleaning
 > 110 XS Double Cab
Post #856441 17th Sep 2020 10:02am
When you use the cutter to clean the seat, how to you prevent crud from falling into the cylinder?
I know it's usual to fit a plug in the hole to prevent this when cleaning the seat with a nylon brush and when cleaning the 'tube', but the plug would presumably interfere with the cutter.
Post #856462 17th Sep 2020 11:42am
hank
The cutter has a pilot rod that goes down the hole both to plug it and maintain concentricity. The crud sticks in the teeth of the cutter and comes out with it. I also blew each hole out with an airline and a bung in place
 > 110 XS Double Cab
Post #856467 17th Sep 2020 11:54am
Thank you, so obvious once you know! Embarassed
Post #856485 17th Sep 2020 12:58pm
hank
Post #856494 17th Sep 2020 2:10pm
ozzie1989
Wales 2010 Defender 110 Puma 2.4 USW Bonatti Grey
Sorry to jump back a bit but where did you get your 'side tube seal' from?
Looks to really tidy up the bottom of the door and may help seal the bottom of my doors in the corners Thumbs Up Now: 2010 2.4 TDCi 110 Utility Wagon
Then: 2004 2.5 TD5 90 Hard Top (X-Tech Edition)
Post #856619 18th Sep 2020 7:54am
hank
I got it on ebay. 3m will do both sides Thumbs Up
https://www.ebay.co.uk/itm/324138668389 > 110 XS Double Cab
Post #856631 18th Sep 2020 9:49am
ozzie1989
Thank you! Thumbs Up Very Happy Now: 2010 2.4 TDCi 110 Utility Wagon
Post #856772 19th Sep 2020 12:59am
